Passenger winodw does not work?
I have an '03 coupe. And the passengers window does not roll up or down. This has been going on for 3 weeks now, it first it ws fine, but now its getting cold!
When I hit the "down" switch on either switch itll make this "click" noise once each time i hit the button.
Sounds like a fuse? any other suggestions? I dont think its a motor because it was working perfectly before. WHere is the fuse for the passengers window?
It's a very common problem for our window motors to go out. My passenger side was going out so I looked at a DIY on our forums to clean the motor and it worked fine for a month or two, then it just died... Try cleaning it/readjusting it and if it doesn't work you'll have to replace the motor.
You might as well just replace it as opposed to tearing everything apart to clean it, at that point it is on borrowed time it might make another month maybe another 6 months but it is going to die so save yourself the repeated head ache.
You can roll it up by hitting the door and holding the switch up at the same time.
Give it a nice soft bang with your fist around the interior door handle section and hold the up switch at the same time.that should allow you to roll it up and down in the mean time.
I've been doing that for the past 3months lol im to lazy to change the motor out.
Micale757
Lighting
Apr 8, 2020 10:46 AM
