G35 & G37, Coupes & Sedans
cusco catch can installed today *pics*
Old Jan 4, 2012 | 11:25 PM
funnyscreenname's Avatar
so a week or so ago i got a few parts from a local guy and one of those parts was a cusco catch can. i had looked at these before but didn't plan on getting one for awhile but, when i was given a great deal i didn't pass it up.
tonite i didn't have much to do so i decided to clean up and polish the catch can and figure out how to mount it. i already knew where i wanted to mount it but just had to figure out how. i ended up modifying the bracket that holds the little spring sensor and used a hose clamp to secure the catch can to the bracket. i just tucked the sensor outta sight toward the fender.
the fittings on the catch can were bigger than the pcv valve and vacuum tube on the manifold. i had to make sure the hose was tight on both the pcv valve and vacuum tube so there wasn't a vacuum leak. i wanted to hide the hoses alittle but, i didn't think making them long and unseen was a good idea as i didn't know if the longer hoses would effect the vacuum. i ended up leaving the return vacuum line long to see if it mattered. i ran it down and then back up into the vacuum tube on the mani. with the engine cover on you only really notice the extra hose between the pcv valve and catch can.
all in all i like the look. when i step back and look at my engine i immediately know i need a jdm battery cover. it's in my plans. i also plan on going with a Z engine cover and polished upper plenum but, i'm not definite. i already have an extra upper plenum and the z engine cover. unfortunately the cover is missing the nissan emblem. i was going to use the weapon r ps fluid tank (seen in the pics) but i changed my mind. just don't think it'll look good IMO. anyway, here's the pics. enjoy.
comments are always welcome
Old Jan 5, 2012 | 12:05 AM
sammy_G's Avatar
does one of the pics show the relocated hood sensor?
cause I cant find it!
Old Jan 5, 2012 | 01:28 PM
that's the idea. i just wanted to hide it. it sitting behind the headlight where it's hiding.
Old Jan 6, 2012 | 11:51 PM
what kinda hose should i ask for from the auto parts store. i noticed my hose collapsing due to vacuum. air is still traveling through but, not as effeciently and i'd like to get bettering hose.
Old Jan 8, 2012 | 01:48 AM
walshtj's Avatar
^Not sure what hose you are talking about, but I like the catch can. Looks good.
Old Jan 8, 2012 | 06:46 AM
mikedamageinc's Avatar
Fuel line is what you want. FI costs little more and is stronger. What are you using that collapses?
Old Jan 8, 2012 | 09:51 AM
gary c's Avatar
I never liked the line/hose that came with any of my catch cans so I use Gates safety stripe CS101206-25 available at quality auto parts stores. This hose will never collapse or leak...Gary
Old Jan 9, 2012 | 12:47 AM
as far as i know it's just oil line. i'll try the fuel line and see if it's stronger under vacuum.
Old Jan 13, 2012 | 07:04 PM
HYDRUS's Avatar
OP, did you ever hear a high pitch whistling when you first installed? Just put mine in a few secs ago and now i have one -___- things always seem to happen like this to me.
Old Jan 19, 2012 | 12:12 AM
it's not really high pitched but, i can hear the suction. at first i thought it was a vacuum leak somewhere. i sprayed some carb cleaner around the ends of the hoses and all and nothing changed so i listened near the tank and finally put my ear to it then i could tell that that is where the sound was coming from.
R350k5
Oct 1, 2015 08:41 PM
RA102223
Aug 15, 2015 09:24 PM
ghost_g35
Aug 7, 2015 10:31 AM
Jussaku
Aug 4, 2015 12:45 PM
lemmy999
Jul 25, 2015 12:13 PM
