G35 & G37, Coupes & Sedans
Failed smog: HFC only mods...advice needed
Old Feb 21, 2012 | 06:14 PM
adamhoud's Avatar
Just barely failed smog today with the only mod being fast intentions high flow cats. See image below. I did just remove the JWT pop charger two days ago and did not reset the ECU...not sure if that would help.
Before resorting to putting stock cats back on I'd like to try other means. I didn't drive it around on the freeway beforehand and heat it up, and it was parked for a bit before it was smogged. I'm also thinking of running some injector cleaner and trying a mix of E85.
Any suggestions/ideas?
Old Feb 21, 2012 | 07:14 PM
gary c's Avatar
Easy fix, swap your OE cats back in and retake the test....you'll pass! You should have left your pop charger on, SMOG techs are normally only concerned about your sniffer test results....Gary
Old Feb 21, 2012 | 07:19 PM
bluedevils95's Avatar
Good to know that i am not ing to get ths now. I dont think one person can pass w/ these on the car.
Old Feb 21, 2012 | 07:39 PM
SDGenius's Avatar
i passed w/my FI HFCs and all my mods. how long have you had your cats?
Old Feb 21, 2012 | 08:08 PM
How long you had yours? Is it a hit or miss w/ these?
Old Feb 21, 2012 | 08:20 PM
SDGenius's Avatar
blew out my Kinetix and failed, bought the FI's and passed. this all happened last fall. it's not really hit or miss, for the 1st SMOG w/them. it's hit or miss if they'll survive till the next one.
Old Feb 21, 2012 | 09:45 PM
adamhoud's Avatar
I only took the pop charger off because I got sick of it and like the drop in better...feels much better all through the range.
I have had my cats in for about 2.5 years now, and I also do have the oil consumption problem. I wouldn't be surprised if my cats had holes in them.
Old Feb 22, 2012 | 12:31 AM
SDGenius's Avatar
hmm, yeah HFCs are pretty sensitive. i burnt out my Kinetix when i drove on a bad coil-pack for too long.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
chinee
Aug 8, 2015 10:11 AM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
