G35 & G37, Coupes & Sedans
Oil change help
Old Mar 7, 2012 | 04:31 PM
denny19's Avatar
Oil change help
So i purchased my '05 G35 coupe a couple of months ago and I just completed my FIRST oil change. I think it was approx 4k-5k miles since the guy before me changed the oil. I used Royal Purple 5w30 oil and RP filter as well.
So everything was fine, except when I went to put the old oil into the empty quart containers, I realized i only filled up 1 and 1/2 quarts with old oil! So I only had a quart and a half of oil in the car?! No "oil" light came on since I have had the car, nothing like that.
Also, the oil dip stick in the G is not very good. Its a pain to get it in the right place, and when I checked it after my oil change, I could not get an accurate reading, there was oil on 3/4 of the dip stick, I only put in 4 1/2 quarts.
Does anybody have any insight?
Old Mar 7, 2012 | 04:35 PM
Jairen's Avatar
Check the oil consumption thread.
VQ's, especially 05-07 manual's are known to burn oil. If your car is still under warranty, you may be eligible for a new motor. There is a TSB for this issue.
Our cars have a very poorly designed dipstick. Readings are horribly inaccurate. Let it sit for 30-40 minutes after driving and/or after filling up with oil.
Old Mar 7, 2012 | 05:14 PM
westbank23's Avatar
damn that sucks..
Old Mar 7, 2012 | 06:37 PM
meG35man@yahoo.'s Avatar
There should be cross hatches on the dip stick. If there is oil on the cross hatches, you are safe. Let it sit, on level groung for 30 or 40 min. as suggested above and check it again. Once the oil is on the cross hatches, it doesn't take much to get it full, so be careful adding oil. FYI you are correct the dip stick location sux. The Auto's also burn a little, it is the nature of the VQ35DE. i have the auto trans.
Old Mar 7, 2012 | 06:48 PM
Shanes_G's Avatar
you need to put in 5 quarts, and the dip stick from high to low indicats 1 quart.
Old Mar 17, 2012 | 01:21 AM
Top Teke's Avatar
Do you mean to say that when you check the oil, if the level is exactly and the low mark (bottom of the hatches) you're only short 1 quart?
Old Mar 17, 2012 | 06:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
That's correct.
Old Mar 17, 2012 | 01:04 PM
Garage Kansai's Avatar
Do not add 5qts . You will be over filling it. The car only holds 4.7qts w/filter. Put 4.5qts and you will be fine. Adding 5 qts to an engine designed to hold less is very bad .
Old Mar 17, 2012 | 01:27 PM
kpowe1's Avatar
Where in the world did you read that, 4.7 qts. Please enlighten me
Old Mar 17, 2012 | 01:41 PM
At my job when I was a mechanic we had to do oil changes on every make and model. And no one could remember all that info. So we had a book that has every make and model from 1990 -> 2012. it also shows dry capacity for evetyrhing , like trans, cooling, eng, diff. I will find out the name when I get back to work monday.
Old Mar 17, 2012 | 01:45 PM
Also go ahead and google maximum oil capacity infiniti g35. And let me know what you find.
Old Mar 17, 2012 | 02:08 PM
kpowe1's Avatar
I'm recalling my service manual calling for 5qts after complete drain. I goggle it just make sure and everything is saying 5 qts, I'm at work now but will double check when I get home just to be 100% sure
Old Mar 17, 2012 | 02:29 PM
Top Teke's Avatar
No. Go ahead and google the weight of a squirrel. And let me know what you find.
Old Mar 17, 2012 | 03:22 PM
Eno's Avatar
Eno
African, or European Squirrel?
Old Mar 17, 2012 | 04:57 PM
Couldn't find squirrel weights but I found this
http://www.new-cars.com/2003/infiniti/infiniti-g35-specs.html
http://www.g35club.org/coupe-specs.shtml
