G35 & G37, Coupes & Sedans
Old Dec 17, 2014 | 07:58 PM
  #3181
ScraggleRock's Avatar
Originally Posted by DigitalDeviant
Yes. Everything is done except the dash and my rear upper plastics which will either be suede or knit depending on which one will match the metallic paint im using on the interior better.
I wanna do that too, but I'm not patient enough to collect each piece. Waiting to find a rear ended specimin, or hoping someone wants to swap for a full willow interior.
Old Dec 17, 2014 | 08:13 PM
  #3182
DigitalDeviant's Avatar
Well mine was already charcoal. I just revived all the plastics and am going full black using sem paint. You can see the results in my progress thread
Old Dec 17, 2014 | 08:18 PM
  #3183
PLENUMCOUPE's Avatar
Alignment print out. Also, for those who have expertise when it comes to sways, I was told adjustable end links are designed so that the sway bars will sit flat. Mine seem to be tilted up a little bit because I have oem end links. Pic is of the rear. Pls chime in if you have some experience with these
Attached Thumbnails What did you do to the G today?-image-504497562.jpg   What did you do to the G today?-image-2936691095.jpg   What did you do to the G today?-image-1352307699.jpg   What did you do to the G today?-image-2797315482.jpg
Old Dec 17, 2014 | 08:29 PM
  #3184
Your alignment sheet is upside down, knee grow. Hangin my head upside down n ****.
Your camber is on point tho. I'd take yer front left down a bit to -0.9 if I were you, but its not that big of a deal.
Old Dec 17, 2014 | 10:19 PM
  #3185
JKL1031's Avatar
That does seem like alot of angle. But they also allow u to pre-load the bar.
Old Dec 17, 2014 | 11:03 PM
  #3186
Mr. Brooks's Avatar
Looking good
Old Dec 17, 2014 | 11:53 PM
  #3187
Your alignment sheet is upside down, knee grow. Hangin my head upside down n ****. Your camber is on point tho. I'd take yer front left down a bit to -0.9 if I were you, but its not that big of a deal.
lolol I woulda taken the front left down a bit but as I'm sure u know, when u do one turn of the kinetix upper a arms it not only affects camber but also caster a little bit. So since everything was green I chose to leave it be.
Old Dec 17, 2014 | 11:54 PM
  #3188
can you explain what u mean by pre-load ?
Old Dec 18, 2014 | 01:42 AM
  #3189
No, caster is the straightness of your entire structure. The only variable on our car that affects caster is the bushings in our compression rods. Its the only part that links our suspension to the chassis.
Old Dec 18, 2014 | 01:57 AM
  #3190
the last 3 alignments I have sat watching my car, the mechanic, and the computer screen. One turn with kinetix upper a-arms does move caster just a little bit. I know for a fact.
Old Dec 19, 2014 | 05:21 PM
  #3191
Installed polk audio MM 6x9s. More to come.
Old Dec 19, 2014 | 07:06 PM
  #3192
JKL1031's Avatar
Did u have to remove the side lugs to get in there?
Old Dec 19, 2014 | 07:09 PM
  #3193
saywat?'s Avatar
today I realized I need to do my pass side valve cover gasket. damn its only been 2 years and less than 10k miles. anyone know if aftermarket gaskets last longer than oem? I see the felspro brand a lot. I thought oem gaskets were good. damn it
Old Dec 19, 2014 | 07:12 PM
  #3194
JKL1031's Avatar
Buy mines buy mines
Old Dec 19, 2014 | 07:50 PM
  #3195
Frankieg35's Avatar
Got my tollboothwilley indertrays powdercoated..
