G35 & G37, Coupes & Sedans
Old Jan 18, 2015 | 01:35 PM
  #3406
DigitalDeviant's Avatar
Watch how you mount the tweeters.. I had a wire touching the bolts from the mirror on the inside and it was causing feedback..
I taped the tweeters after my first attempt seeing that same problem.
Old Jan 18, 2015 | 01:47 PM
  #3407
Frankieg35's Avatar
Yeah, I did the same thing..
Old Jan 18, 2015 | 04:10 PM
  #3408
saywat?'s Avatar
Koo didn't kno, I'm guessing, the newer gs had the blk door panel cover?
Old Jan 19, 2015 | 01:54 PM
  #3409
Frankie324's Avatar
I dipped my grill yesterday. Looks nice.
Old Jan 19, 2015 | 06:08 PM
  #3410
JKL1031's Avatar
SOB! I knew it made no sense why my axles were clicking only going forward and not reverse. turns out it was my diff brace that was loose/rubbing the subframe this whole time. I swear it sounded just like clicking axles.
Old Jan 19, 2015 | 06:47 PM
  #3411
Urbanengineer's Avatar
Nice work Frankie.
Old Jan 19, 2015 | 11:43 PM
  #3412
Hotdawwgman's Avatar
Forgot... I popped in a K&N air filter in the hotdawwg mobile...
Old Jan 20, 2015 | 08:41 AM
  #3413
Hatchman's Avatar
Replace the low beam with Philips X-treme D2R bulbs, claim to be 50% than the stock "regular" Philips. And they are, I would say they are double the light of my stock bulbs, which could possibly be the ten year old ones from the factory.
Also replaced the fog/Hi beam with Philips X-treme halogen bulbs, which claim to be 150% brighter... which I would say is also a fair estimate. The low beam is a nice, wide pattern, and the high beam is insane. Not the best "spread" using the high beam, it has a very narrow beam that shoots out very far, but not that wide at all. Probably more of the reflector's fault than the bulb. Also the passenger side high beam fires a little to the left (even though the low beam seems fine), so when you kick in the high beam, they both go straight into the oncoming traffic lane at eye level. Needless to say, these will blind oncoming traffic, big time.
Also replace the front side markers with some black frame, clear lense markers. Much better output than my old "smoked" lenses that seemed to "suck" water every time it rained. Seal on the new ones is much better, so hopefully no more foggy lenses.
Overall, much better lighting than before.
Old Jan 20, 2015 | 08:54 AM
  #3414
JKL1031's Avatar
D2R is for the non projector lens right? I may look into it.
Old Jan 20, 2015 | 09:11 AM
  #3415
Shawno72's Avatar
I have seen these before on Ebay. They are pretty pricey, is it worth the additional cost? Also what did you pay if I may ask
Old Jan 20, 2015 | 02:00 PM
  #3416
Loitz30's Avatar
What I've done this month
Started off the month with a new set of tires for the coupe. About 3 days later fried my clutch, so I went with the JWT clutch flywheel combo. Also picked up the 5/16 spacer, stillen ztube and high flow intake. Figured while I was doing that I'd change the spark plugs since I just hit 90k. They looked like **** so I picked up some NGK iridium plugs to put in. In the process of changing them I noticed oil in number 6 so had to get a new valve cover. The damn thing is going to take a week and a half to get here so it's been about a month of my car being down and not the most friendly to the bank account. I'm itching to get it all fired up and running again.
Old Jan 20, 2015 | 02:14 PM
  #3417
Hatchman's Avatar
Yes, the 2003-2005 G35s use D2R size bulbs. The 06+ use D2S.
Yes, they are pretty pricey. I got them from hidconcept on sale for around $130 a pair, regular $180 from them.
I would say they are worth it, since my old bulbs were pretty dim for HIDs. They probably were ten years old, so time for them to go. If your low beams are looking good, I probably wouldn't bother, but mine were in sad shape, so figured why not go ahead and get the X-treme over the ebay no name bulbs. I've heard a lot of horror stories on the ebay no name bulbs, blow after a week, don't fit right, flicker on and off, etc.
The Philips are a perfect fit, which makes sense because they put in Philips at the factory.
Old Jan 20, 2015 | 04:18 PM
  #3418
Deepdiver's Avatar
smog test.....very boring.
Old Jan 20, 2015 | 09:22 PM
  #3419
Getting my tablet closer to being installed.....
Old Jan 20, 2015 | 09:44 PM
  #3420
JKL1031's Avatar
Gtr!!
