#5282
#5284
#5285
Oh I am. it's about to get all the ball joints replaced. Looking into a bottle-jack press so I dont need to buy controls arms. Just bought new bearing for the pulleys friday.
I'm the 3rd owner. 1st one had it for 9 years, second one was either a stoner or maybe drug dealer. It reeked of weed and stale cigarettes, found 7 rounds of .45 and 5 .22lr buried under the carpet of the trunk, and pay stubs of like $600, but a bank account balance of $24k so something doesn't add up there lol. All I know is the jiffy lube there worked on the radiator and I still cant get all the air out of the system after 4 burps lol. Gotta love used cars. She'll be in great shape this spring.
#5286
Installed the RJM Rev 4 Clutch Bracket with help from ACIDJAKE - MY350z Mod
http://www.rjmperformance.com/350z--...edal-kits.html
Benefits of the RJM AFP Pedal System
- Smoother Launches with more Control, Lower Friction Point and Predictable Engagement!
- Much Smoother 1-2 & 2-3 Upshifts Shifts
- Smoother and easier 4-3 & 3-2 Downshifts!
- Improvement in Pedal Feel & Clutch Control for all clutches OEM to Extreme Multi-plate and Heavy Puck clutches.
- Adjustable for Stroke Length, Pedal Angle/Height, Friction Point & Pedal Pressure!
- Features a Single Acting Torsion Return Spring & Eliminates the Factory "Assist Spring Mechanism".
- New Rev 4 Features increased adjustment capabilities over older versions for more setup flexibility.
- ZERO Pedal sticking to the floor after Hard Driving, Track Days or Events
- Reduces or Eliminates chance of CSC failures on 07-08 HR 350Z.
The Rev 4.0 Assemblies Have Been Completely Redesigned as Full Replacement Pedal Assemblies Allowing:
- Faster & Easier to Install than previous versions.
- Simpler Tuning Process than previous versions.
- Reduced Number of Install Steps.
- New Simpler AFP Adjustment Mechanism featuring a built in scale to see exact AFP Setup Percentage.
- Comes as a Complete Pre-Assembled Replacement Assembly, AFP comes Pre-Adjusted to reduce setup.
#5287
#5288
Being able to feel the engagement point is only one part of the issue. The factory clutch has such a high engagement point and stroke is really long also the modulation zone is very short/tight. With the adjustable pedal you can choose how long of a stroke, where the engagement point is and the pedal height in relation to brake pedal. I hated having my clutch pedal higher than brake. I hated having engagement point so high compared to other vehicles. I hated having a short modulation window. Also don't forget the jerky launch, 1-2 upshift, or 2-3 upshift and also downshifts.. Launch is extremely smooth, no more bucking, jerking, guessing where engagement point is or a really long stroke.
I have increased leverage so rush hour shifting is a joy. I actually look forward to the commute in the morning with the new pedal. Folks are willing to waste money on exhaust which only makes noise and barely any blip on the dyno, wheels that poke and require you to run extreme camber (eats up tires) but yet are not willing to spend $239 on a clutch bracket which gets used 100 times a day or more. Instead of feathering your clutch for smooth shifts pick up a bracket and save your disc.
#5289
I did the initial mod which is removing the spring and adjusting the clutch rod. That was pretty good for 4 years. I did the first prototype RJM pedal install in ACIDJAKES car and he absolutely loved it with his JWT Clutch. I wish I would have bought a bracket in 2012 instead of waiting 3 years.
faiz23 (12-09-2015)
#5290
It's garage kept and if I know it's gonna rain I'll avoid driving it. Yea, tons of room for activities in there lol, I actually just sold my nwp tb and 3.5 inch furookie. I'm honestly done modding it, that clutch pedal looks nice tho. I hate when mine doesn't come all the way up.
#5292
I just pulled my wipers to do the hood hinge lube mod.
#5294
So I had purchased an auto sensing windshield wiper system but had not installed it because it came with a dinky "on-off" switch. it didnt meet my standards of oem looks so i decided to hack apart my existing windshield wiper stalk. i notched where the "mist" function goes so it doesnt just return. it clicks into place and then cut the contact pads for the mist function and soldered my own wires to the contacts. now when the wiper is put into the mist function it will turn on the auto wiper function. now i just gotta clean off the "mist" letters and get a laser cut stencil for "auto" and spray it
The following 2 users liked this post by .cakestar:
BradMD_96 (12-09-2015),
Frankieg35 (12-08-2015)
