#6259
Edit : Also forgot to include that on the passenger side, when I get the castle nut tight, it ends up spinning the actual rod.
#6261
#6262
I inspected all bushings and they seemed to be fine. One thing I did notice that was odd was that on the actual adjustment part of the SPC arm (the threaded rod that receives the conical bushing) I could run the castle nut up way higher than the hole for the cotter pin. Also it seemed that the conical bushing slid higher up on the rod, as in it was squishing the red rubber, on the passenger side but not on the drivers side (and the conical bushing would fall off if not receiving any pressure). Drivers side seemed fine, just the passenger side was weird. Any help?
It sounds like you are missing the cone shaped bushing that goes between the ball joint and the knuckle, or you have the wrong ones. It definitely shouldn't do what you're describing.
#6263
I missed that you already have SPC arms. The castor should be able to be adjusted, but finding a tech who will take the 10 minutes to read the instructions can be a challenge.
#6264
#6265
Got my whole front end repainted, front splashguards, wiper cowl, wiper arms, painted the jdm bump sidemarkers, shaved the headlights bezels and repainted those, did the clear lense on the projector, did a passive red demon eye, hid fog lights, and got the emblemless grill installed.. I still have to installed my carbon fiber front splitter from outcast and cf mirror bases..
#6266
_Ghost_G35 (07-11-2016)
#6270
