G35 Glass Headlight ?
#46
The G and Z are pretty bad about their windshields being easy to damage.
I don't know if it's because Nissan used cheap glass, the cars are low to the ground, or a combination of both. I have a chip and a small star in mine from trucks on the highway, as well as little speckles of damage that you can't see unless the sun hits just right.
#47
My 2000 Toyota 4Runner has glass headlight and I love it. Plastic headlight probably a standard because of DOT.
I combat hazy plastic headlights by sanding with 600 grit then 1500 grit and laying down 2 coats of clear. I used Sherwin-Williams. I just polish the lights when I do the paint
try look up my work on Tumblr. Screen Name is Driven
silvG35 (08-09-2012)
#48
#49
bTanz
10-15-2015 02:31 PM
laksjd84
07-24-2015 05:12 PM
2005, cracked, g35, glass, headlight, headlights, housing, infinitig35, make, protection, scratched, shatter, switch, toothpaste, uv
