G35 & G37, Coupes & Sedans
installed my engine damper tonight
Old Sep 14, 2012 | 08:01 PM
kristof's Avatar
I was wondering about these for my V36. I had one on my last car which was FWD and it helped eliminate wheel hop along with full poly mounts for the motor/trans.
Old Apr 6, 2013 | 10:10 AM
=CPV35='s Avatar
just wondering did you tighten the damper ends before you installed it?
I have the same one from ebay and the damper arrived "loose" on the round end bit, it's hard to explain but it's the bit at the end of the damper where you can turn, did you do it tight??
Old Apr 8, 2013 | 12:46 PM
evil-G-nius's Avatar
Question...did you install only one? I have seen (on other cars) two dampers...one for movement back to front and one for side to side....if any.
Old Dec 9, 2018 | 12:27 AM
binoBrown's Avatar
G35x
Hate to revive an old thread but I was planning on ordering the same torque damper. The parts that I keep finding on eBay seem to not fit my car. Does anyone have a link to the one for an 04 auto sedan?
Thanks in advance.
Old Dec 9, 2018 | 03:02 AM
Urbanengineer's Avatar
Thanks in advance.
It's the same for 03-06 afaik, and it's not making a performance difference.
Why? If the engine mounts are toast it's always moving crazy.
Old Dec 9, 2018 | 07:11 AM
binoBrown's Avatar
G35x
I agree about the performance aspect but my thinking is the damper would help a little with the engine movement and will be a lot cheaper and less time costly than replacing the mounts.
Old Dec 9, 2018 | 10:12 AM
cswlightning's Avatar
I had one of these on my car, and when it broke in half I immediately noticed something was wrong and there was way more movement. I didn't fix it, and 6 months later I had a completely torn engine mount. The damper would have restricted the motion enough to prevent damage to the mount.
Could also try injecting your stock fluid filled mounts with polyurethane!
R350k5
Oct 1, 2015 08:41 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
