G35 & G37, Coupes & Sedans
installed the rear 350z stechs about to do the fronts right now
Old Sep 11, 2012 | 11:09 PM
hippiGlass's Avatar
ok well i just ran into a problem with the driver side that i didnt on the other... got the new spring on and when i go to put it back on ill put it in the top 3 holes but then the lower mount on the shock is at a different angle to the mount on the lower arm...and twisting it in to place doesnt work.. do i gotta loosen up the top bolt again and twist back maybe? idk kinda stumped...
Old Sep 11, 2012 | 11:13 PM
gary c's Avatar
You can't install springs and expect to see a difference until you drive it around the block once or twice or set over night then driven! With the Tein350Z S-Techs there shouldn't be more than a half inch gap over the top of your rear tires and even less in front. Before you jump on the spring mount mod let it sit for a couple days and consider the height of your exhaust tips when backing into parking spaces where curbs are involved....Gary
Old Sep 12, 2012 | 12:54 AM
hippiGlass's Avatar
good deal gary ill wait on it, just finished the fronts...firgured out the problem i had..the fronts definitely sit lower then the rear.. i drive it around for a few days.. im sure my dirt road will help a lil faster.. anyway thanks for all the info on this..pix uploading right now ill post in a few min
here they are right after installing them
Old Sep 12, 2012 | 04:28 PM
hippiGlass's Avatar
just went and drove the car around down...filled up my tank and the rear settled a lil more...i cant def tell the car is lower then it was cause im scraping on stuff i never used to scrape on b4...i am suprised i thought the alignment would be off a lot more then it is but it still drives straight...the camber isnt bad but it is there.. gonna be getting the rear camber kit soon, i noticed SPC has 2 rear kits the reg and the extreme.. what one is better to get? im guessing i dont "need" the extreme?
Old Sep 12, 2012 | 04:32 PM
saywat?'s Avatar
hmm looks like u got 350z springs on. the drop is really subtle.
Old Sep 13, 2012 | 03:41 AM
2plus2sixMT's Avatar
The springs you installed are green right? I assumed the car would look lower.
Old Sep 13, 2012 | 03:56 AM
hippiGlass's Avatar
ya green springs..ill get a better pic tomorrow, i did the rear spring mount mod tonight and it looks a lot better.. its about 1 finger gap front and rear now.. it looks lower then in the pix above now.. the flood lights i had on the house made a lot of shadows in the pic.. i have a day time pic but its b4 the rear spring mount was cut..
b4 i cut the spring mount..
heres a pic of the rear after the spring mount
stock 18" rims and tires to.. i noticed most others on here with the 350z springs have 19s or 20s and that puts the tire well into the wheel well soo would make it look a lil lower im guessing.. it seems a lot lower then what it was stock to me now, its definitely not slammed but it scrapes on **** it didnt used to before lol soo its low enough... if i ever want to go lower one day id have to bag it just so i could lift it up if needed..
Old Sep 13, 2012 | 04:17 AM
Ok. Looks lower in the sunlight. My car looks lower/higher sometimes. Don't know if its just the angle or shadows or how its parked.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
