G35 & G37, Coupes & Sedans
Car acting up
Old Nov 3, 2012 | 04:04 AM
dj714's Avatar
Angry Car acting up
Recently my 06AT coupe started acting up. When I hit 80 on the speedometer it's starts to jerk and lowers speed. Anybody have this issue?
Old Nov 3, 2012 | 07:20 AM
SUMATIC's Avatar
sounds like you got a limiter on it.
Old Nov 3, 2012 | 09:26 AM
AuAltima3.5's Avatar
Did it go over 80 before? Did you just buy it?
Is there a check engine light on?
Does it rev over 3k in other gears? Like from a stop?
If the speedo is acting weird maybe is a vehicle speed sensor (not sure how the G does speed calculation, maybe uses some other sensors).
Lots to look into, give us some more info.
Old Nov 3, 2012 | 12:10 PM
dj714's Avatar
I just traded for it about 3 months ago and I don't remember having any issues like that before.
I've had the SES light on since I got it its a P0011 (camshaft sensor)
Recently changed it with a autozone sensor and light went off for a couple miles then came back on.
Old Nov 3, 2012 | 12:21 PM
Mustang5L5's Avatar
Have you checked the code recently? Could have a new code stored now.
Out of curiousity, are your tires different diameters?
Old Nov 3, 2012 | 12:25 PM
dj714's Avatar
Yes had it checked the following day after I changed the sensor and it came back with the same P0011 code. My tires are 235/30/20 all around
Old Nov 3, 2012 | 05:48 PM
dj714's Avatar
How can I check for this and also get ride of it?
Old Nov 3, 2012 | 11:11 PM
tle.88's Avatar
I'm pretty sure it your camshaft sensors man. There two of them (passenger and driver side). I would recommend to replace them with factory ones.
Old Nov 4, 2012 | 08:21 AM
DailyDrivenCoupe's Avatar
yeah i would look more into the cam sensors and make sure you replaced the correct bank and also go back with the oem sensors as stated above. try to search p0011 on the search feature on this site and see if it can point you in the right direction
Old Nov 4, 2012 | 09:56 PM
JayVQ's Avatar
Have you checked your oil level?
Had the same code pop up in my Altima 3.5 SE and it made the car do strange things. The whole thing was causes by a low oil level.
Old Nov 6, 2012 | 03:02 PM
Mustang5L5's Avatar
P0011 is a camshaft sensor as you already know.
I'd start there. Your issue might not be speed related, and more RPM related instead. Either way, the code and the symptoms point to a camshaft sensor being a highly probably possibility as to the cause.
Old Nov 6, 2012 | 08:27 PM
Adil_G35's Avatar
autozone is crap. dont ever try to replace oem parts with their junk
Old Nov 6, 2012 | 08:48 PM
dj714's Avatar
Yes your rite but figured it was worth a shot will replaced it one time and if its still doesn't work i will be going to get my money back and get it the oem one and at that point if its still doesn't fix it then its going to the shop.
Old Nov 6, 2012 | 08:51 PM
hurleyguys's Avatar
if you need a recommendation for a good shop look up corner 3 garage in Lake Forest. really great guys there and they wont bullshit you and try to sell you **** you don't need. and they will check your codes for free. They are the only ones i let work on my car.
Old Nov 6, 2012 | 09:07 PM
dj714's Avatar
How are the prices?
