G35 & G37, Coupes & Sedans
Starting My 6MT
Old Jun 4, 2013 | 12:23 PM
dofu's Avatar
20 Year Member
Originally Posted by Golden_Shower
My Viper 5901 has a huge disclaimer in the manual about remote starting a manual transmission, then right under it, it tells you how to operate the manual transmission remote start system. This is not a new alarm system by anymeans and it has a fail safe built into it which will not allow the car to start with one touch remote start button if the car is in gear or if the hood is open. This set up does not work on all cars but I know for a fact that if wired correctly a g35 will not start if it is in gear.
The clutch overide was always active on my car once the alarm was installed, which means as long as the alarm box had power running through it, armed or unarmed I could start the car in nutral without the clutch.
FYI
Nissans/Infinitis have a Neutral Safety Switch that your installer can tap into for 6MT remote start.
I had a Clifford G4 on my G and it had none of that. I still had to step on the clutch to manually start the car, and it didn't come with any fail safe.
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
kenthung
Jul 21, 2015 05:56 AM
