G35 & G37, Coupes & Sedans
Ok to use 87 octane gas on an 04 g35 sedan AT?
Old Oct 3, 2013 | 03:20 PM
Mustang5L5's Avatar
Does anyone have an 03-04 manual?
Can you post what it says for recommended fuel octane?
Old Oct 3, 2013 | 03:54 PM
Gman56's Avatar
You can run 87. Yes 91-93 costs .20-.25 cents more but I know I gain two more miles per gallon on 93 than 87.Plus get better perfomance. I only put 93 in my G.
Old Oct 3, 2013 | 04:22 PM
telcoman's Avatar
Veteran: Army
Search is your friend
http://pdfcast.org/pdf/2004-infiniti-g35-owners-manual
Telcoman
Old Oct 3, 2013 | 04:38 PM
Peoria35sedan's Avatar
It's exactly the same as the 05. For what it's worth I've run 87 in my car before and after getting it tuned, before the tune, you couldn't tell it was 87, after it pings if you get on it in the standard performance map. I think the difference between the coupe and sedan is the map.
Old Oct 3, 2013 | 05:32 PM
telcoman's Avatar
Veteran: Army
I did not experience an increase in performance or increased MPG when I tried both 91 and 93 octane
So far on my G37 I've used 1045 gallons @ $.36/gallon savings using regular I've saved $376.00
On my 06 G35 over 171796 miles I used 7170 gallons of regular. X $.30 /gallon savings, I' saved $2581.00. Total the two vehicle savings by using regular I've saved almost three thousand dollars.
Better in my pocket than the oil companies
Telcoman
Old Oct 3, 2013 | 05:44 PM
dofu's Avatar
20 Year Member
If anything it might be the difference between sport and non-sport models: the sport models might have a bit more advanced timing from the factory, meaning you will need the higher octane. The difference is still not between sedan or coupe.
Telcoman
You won't see a huge difference in performance between anything above 91 on stock motors and daily driving. Out here in CA, we have 87, 89 and 91. Some gas stations have 100 as well. But once you start modding and tuning, there will be a difference in overall power output.
Old Oct 3, 2013 | 09:47 PM
Mustang5L5's Avatar
t.
The factory tends to leave a lot off the table for safety sake as well as trying to adapt a car to run in the many various environmental conditions a car driven in this country will see.
For example:
Cars can run well on lower octane at high elevation. You tend to find 85 octane in the mountains, and 93 octane near sea level. This is related to the density of the air at lower elevations.
Cars also tend to detonate in higher temps, than lower temps.
They also detonate more in dry air, vs humid air. I know from my drag racing experience in my mustang (hundreds of passes for several years when I used to compete in amateur events) that in the fall when humidity dropped, I would back my timing down to prevent detonation. It would always been in the fall when the humidity dropped like a rock. Car would ping like crazy and I'd either up the octane level, or drop the timing down.
Also, octane requirements tend to rise as the vehicle ages. Carbon deposits in the combustion chamber can raise compression ratio as well as cause the fuel to pre ignite.
So just those 4 things alone make a difference considering the varied terrain and climate in this country that engineers had to adapt to. So for example, a brand new car running 87 octane, at higher elevation where it's cooler with average humidity, may run beautifully. Now that same model car, but with 150k miles in Death Valley where is below sea level, hot as hell and dry with little humidity, may detonate like crazy on the same octane. Same factory tune, just different circumstances.
So it's hard to issue a blanket statement as to which octane to run. There are many, many factor to consider. What works for one person, won't work for another. There are a lot of "behind the scenes" factors that some guys never think about.
Another thing....knock sensors can fail. Typically you really don't want to rely on them to save your car because if they fail, you can damage your head and pistons. That can get very, very expensive.
For some....higher octane can be a form of insurance. For others, it is a waste of cash.
In all the forums I'm a member of....the octane threads tend to be the most passionate.
I own 3 cars....and actually run different octanes in all 3 for different reasons.
Old Oct 4, 2013 | 05:10 AM
telcoman's Avatar
Veteran: Army
Mod money goes into my 401k plan
Old Oct 4, 2013 | 06:26 AM
Urbanengineer's Avatar
Telco man thanks for the very factual data. Could you throw up your unique data like elevation and mpg average for each of the three octanes? Or is it you only tried premium for a month?
Thanks!
Old Oct 4, 2013 | 07:17 AM
telcoman's Avatar
Veteran: Army
Thanks!
Only tried 91 for a month and 93 for a month for a total of two months.
BTW I can't speak for all dealers but my two new Infiniti's came delivered with a full tank of regular.gasoline.
Does anyone really believe dealers are going to spend the extra money to deliver a new vehicle with a full tank of premium
My test hill
The elevation rises from 52ft above sea level at the bottom of the hill to 175 ft above sea level at the top a distance of over 1/2 mile.
Test results on my06 G35
Old Oct 4, 2013 | 08:36 AM
Mustang5L5's Avatar
mod money goes into my 401k plan
+1.
Old Oct 4, 2013 | 09:06 AM
telcoman's Avatar
Veteran: Army
For example:
You are correct!
I've been making the same 50 mile trip to work for the past 15 years having driven over 200k miles
I fill up here
Then two traffic lights before reaching the NJ Turnpike for 10 miles to the Garden State Parkway.
The only difference is morning temperature.
Better
The best at 63 degrees and 37% humidity
Same 50 miles trip, same gas, different temperatures,humidity, and barometric pressure
Telcoman
Old Oct 4, 2013 | 09:16 AM
thegreatkwijibo's Avatar
Old guys
Old Oct 4, 2013 | 09:51 AM
Mustang5L5's Avatar
Originally Posted by thegreatkwijibo
Old guys
I'd like to retire by 50.
Old Oct 4, 2013 | 10:16 AM
  #30
Gman56's Avatar
I did first yr was great! Second yr spent alot of time on my hobbies and riding my harley.Third yr it started to get boring hobbies just wasnt fun like it use to be.Riding still is good just get tired riding alone my friends are still working. I still like not having to work. If its nice I cruise to the old job see how work is lol.
