G35 & G37, Coupes & Sedans
taking strut apart
Old Mar 20, 2015 | 03:25 PM
TurTLe*'s Avatar
taking strut apart
Trying to help a friend with their car, I've always just bolted on spring compressors and impacted the top nut off. Rarely would i have to use a hex,torx or whatever.
Until now.... This nut loosen a little but now is spinning along with the shaft. I unloaded some of the tension and did it by hand with a 17mm box end and pliers/vice grips. Nothing doing. Sprayed tons of PB blaster. Still wont come off. No torch on hand but with it being soaked with PB blaster, not sure if its a good idea anyways.
I put it back on the car and tried to remove it with the body holding it together, still spinning.
The rod just spins with the nut. I tried to pick up this tool...
Amazon.com: Lisle 20400 Universal Shock Absorber Tool: Automotive Amazon.com: Lisle 20400 Universal Shock Absorber Tool: Automotive
sadly it wasn't the rod was thicker then any of the sizes.
Old Mar 21, 2015 | 01:03 PM
telcoman's Avatar
Veteran: Army
Have you tried following the steps in the FSM?
Telcoman
Old Mar 21, 2015 | 03:08 PM
TurTLe*'s Avatar
FSM tells me to just impact them off after spring compressors are installed on them... it aint working.
Old Mar 24, 2015 | 10:05 AM
coffeysm's Avatar
I had this same problem and ended up having to Dremel the nuts off on both of them.
I've used PB Blaster with a torch before and it hasn't caused an issue. Now, if you spray the bottle AT the torch then you're in for some serious problems. It just makes a tiny little flame if that when you hit the bolt with a torch.
snic09
Nov 8, 2017 01:46 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
twining24
Aug 19, 2015 05:29 PM
itschuckster
Jul 25, 2015 08:07 AM
