G35 & G37, Coupes & Sedans
engine light, vdc, and slip light is on. Plz help if you can
Old May 7, 2015 | 02:57 AM
Mrs.Valdez23's Avatar
Plz give me good info if you can, ill appreciate it. My g35 is acting up takes a few seconds to start up, once I hit 60mph it does like a lil light jump and then the vdc off light aswell with the slip light turns on. Once I stop , turn off try turning back on it'll take a few seconds to turn on. I'll turn it off let it sit , then turn it back on and it turns on regular. Vdc , and slip light is off but engine light is on. But once u hit 60mph it'll do it again . Some times it'll just stall out of no where. It says camshaft sensor on the diagnostic, but I read and say it doesn't work. I see last post was awhile back so it might be fixed already? I need as much as info I am pregnant and wanna be safe while I'm driving.
Old May 7, 2015 | 08:43 AM
Urbanengineer's Avatar
Interesting. Can sensors should put up a check engine light on the dash. Try getting it diagnosed for sure at a parts store with a car scanner. Auto zone sells Duralast sensors that work fine as OEM replacements.
Old May 7, 2015 | 09:30 AM
G35
I have, camshaft sensor pops up. I let it sit for a bit and reset and take off the lights and it's good but there's times where it just happens out of no where, I really don't feel safe driving it. I seen the code but that's the code every body goes thru and it ends up not working. 2 weeks ago I got kar washed and right when I left it wouldn't started like it didn't have no gas it'll have to sit a bit for it to start. Then this pops up.
Old May 7, 2015 | 09:40 AM
infiniti35
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
