G35 & G37, Coupes & Sedans
hummin in front diff.
Old Jan 10, 2016 | 10:39 PM
Svt2aG's Avatar
i recently bout a 06 g35x with a broken front drive shaft, which bcuz the diff is bolted to the upper oil pan also has a hairline crack in the lip of the pan and down bout an inch,plus a few other issues from the shaft slappin around in there, i temporarily sealed the pan to get it on the road, its still not registered but i took it for a spin after installing the new shaft from wholesaleimports, and was hearing a low humming noise other wise the motor and trans feel great, also have the traction light on but no codes except o2 sensor, any theories on the humming would b appretiated, i do plan on replacing the pan or having it welded but since the driverside cv shaft goes thru the pan via a pipe wit so orings from wut i saw i tryna wait for better weather
plz any ideas or suggestions may help
Old Jan 15, 2016 | 03:42 PM
Mustang5L5's Avatar
Do you have fluid in the differential?
Humming in the front can be the diff, but could also be the wheel bearings which is a common problem on the AWD G35's. They tend to go early and make a humming/vibration when they are bad.
Cross your fingers that it's not the diff, as it's a PITA to replace.
Traction control (VDC light) being on will not generate a code via the OBD2 diagnostic port. You'll need a Consult-II to get those codes. Is the ABS light on as well? Could be a yaw sensor or ABS wheel sensor but no way to know unless you read that specific set of codes.
kvp35
Jan 11, 2016 01:31 AM
vrracing
Jan 8, 2016 01:19 AM
jjuriga
Jan 1, 2016 08:18 AM
drosu1977
Dec 30, 2015 09:38 PM
Shanes_G
Drivetrain
Dec 22, 2015 10:29 AM
