G35 & G37, Coupes & Sedans
Cleaned throttle body and severely messed something up
Old Feb 4, 2018 | 04:44 PM
G_35J3FF's Avatar
so I have a 07 G35x with 140,000 Miles about and when I took it in for an oil change last they said I should probably get the throttle body cleaned, I decided I to try and save $60 and do it myself without knowing what I was doing. After the “cleaning job” I did the car idled like ****. It either idles at 1800rpms or it jumps back and fourth from 1200-1800 and when I put it in drive it lowers to about 1000 rpms. I’ve tried the peddle dance I’ve tried actually taking both throttle bodies off and cleaning them the correct way (unplugging the battery and sensor then gentely cleaning the butterfly) nothing worked. I tested which throttle body was messed up by having the car started and unplugging each throttle body to see which one did what and the passenger side dropped rpms drastically to about what it should be (650) and when I turned the car off and back on then unplugged the driver side the Rpms stayed the same. I figured the driver side was bad and replaced it then did the resets and the Lil bitch is doing the same thing. I also ran sea foam through the tank. Next option is calling Infiniti and having the codes reset for $90 but who knows if that’ll even work. Please help! Thanks
Old Feb 4, 2018 | 05:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you unplugged the throttle bodies you ABSOLUTELY MUST perform the TB recalibration so the ECU knows what position the motor is in.
Page 79 of the Factory Service Manual (FSM) has the steps to perform, read the "without Consult II" ones, it's nicknamed the "pedal dance" and you MUST use a clock that can accurately measure seconds because the timing is exact. It might take multiple attempts if you are screwing up the timing.
http://www.nicoclub.com/service-manu...7_G35_Coupe/ec
There are no "codes to reset" that will fix this. The ECU needs to relearn the position of both throttle bodies (if HR, else single TB for DE) as well as a re-learn algorithm for idle air volume which MUST be performed when the engine is at operating temperature.
These things are mostly computer so dicking around unplugging stuff or unbolting stuff without knowing what you're doing is going to cause massive problems for the user.
Old Feb 4, 2018 | 05:25 PM
G_35J3FF's Avatar
Sweet
yea I’ve done enough unplugging and dicking around lol I did the idle relearn aka peddle dance and to reset the ECU is just to disconnect the battery and discharge all voltage or whatever. I’ve done the relearn so many times I don’t need a stop watch lol
Old Feb 4, 2018 | 05:38 PM
telcoman's Avatar
Veteran: Army
Well you saved $60.00
Telcoman
Old Feb 4, 2018 | 05:40 PM
G_35J3FF's Avatar
And I learned a valuable lesson 😂
Telcoman
dont try to cheap out on my car
esotericrider
Feb 14, 2022 07:19 AM
kingrukus
12
Jun 13, 2008 04:46 PM
