G35 & G37, Coupes & Sedans
New User, Window Issues
Old May 2, 2018 | 01:04 AM
Paraph's Avatar
2003 G35 Coupe 6MT
What's up all, new user so I apologize if I'm posting in the wrong section, it's 1am for me and I'm trying to get my problem out there asap so I can go to bed.
Passenger side window will not go up or down using power window controls on either door, despite the fact that the drivers side works fine using the switch. Passenger window motor does work, held down the unlock button on fob and the window rolled down just fine, now it won't go back up. What would the next thing to check be?
Thanks again, I'll get the forums figured out tomorrow afternoon so I'm not popping up on the wrong threads for future use & I appreciate any help I can get.
Old May 2, 2018 | 11:48 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take off the panel and unplug the harness to the window motor, use a digital multimeter and hold the window switch up/down while you check for voltage. Polarity will swap when you change up/down. This will eliminate the wiring and switches as the problem if you have proper voltage.
Does the window still drop 1/2" when you press the door closed switch while the door is open? If not you need to be VERY careful because you can't close the door with the window rolled up all the way or it can shatter the glass.
Old May 2, 2018 | 02:37 PM
Urbanengineer's Avatar
Make sure the passenger switch lock is unclicked. Ask me how I know....
Old May 3, 2018 | 05:29 PM
FreshLikeAG's Avatar
Lol. Same thing happened to me. Never used that button before and must have been pressed cleaning the panel or something. Took some time to figure it out
That Black G35
Feb 9, 2011 10:47 PM
Jeff92se
12
Dec 26, 2008 03:04 AM
blownvert
Mar 11, 2008 09:51 PM
Waz350GT
Jan 20, 2008 03:54 AM
