Excellent! Glad to hear things are becoming more clear. Only concern I have is that I hope the 2005 harness connector is compatible with the new tuner socket. If not, you'll have to figure out if there is an adapter/dongle to do that, or bailing wire and bubble gum your own after figuring out the pin layout. Feel free to PM me with any install questions you may have. You'll definitely want to have a lot of zip ties....
Congrats on the new G! I would say you paid a little high on it. I bought my 2006 G35 Sedan in 2016 for 5k with 121k miles. It was a base model though and some of the paint was chipping on the hood and fender.
They're great vehicles for sure though. They have pretty good power, are pretty reliable if taken care of, have nice luxury features, and look great. At 150k miles you want to make sure the following was replaced:
Fuel pump
Radiator
Rear wheel bearings
Alternator
Valve cover gasket
I had to replace the steering rack
Spark plugs
All the rubber components of the suspension
Shocks
Brake pads and rotors
If any if the above mentioned parts are original, be sure to replace it as soon as you can.
Yeah I like this forum too because most people here are either knowledgeable or intelligent or willing to learn or both.... the same cannot be said about the G/Z community at large, at least in my area....
Bone stock G35, got everything but sirius radio. :(
Dude, You sure know how to rain on a guy's parade!
Here I hoped all was right with the world and now your casting doubt in my mind and I'll worry till it gets here......
Fuel pump
Radiator
Rear wheel bearings
Alternator
Valve cover gasket
Spark plugs
Shocks
Maybe I did.
Mine has every option on it.
The body is 10/10
The Paint is 10/10
The interior is 9.9999/10
The only issue is my clock don't work on the dash.
It's kinda high mileage but I was tired of the Corvette so I needed a change and a more practical car.
If you do have an issue with the wiring there's probably an answer hidden inside the audio/visual subforum. There's also an INCREDIBLY knowledgeable guy named Wrathernaut who keep those subforums well oiled.
*groan*
I don't think the tuner Sirius sent me (hasn't arrived yet) is what I needed, I searched the part number they shipped and got a picture and it is NOT what I wanted.......but am not sure if it might work or not.
Here's what they are sending me.......
Will this work? Instead of being in the trunk will this plug into the back of the head unit.....then I will just have to run the antenna to the rear deck? Please tell me it will ,please, please, please.........
Or am I going to have to return it and order the correct receiver for the trunk.....
