G35 & G37, Coupes & Sedans
Should I buy these toe arms??
Old Apr 30, 2019 | 04:07 AM
Ichiglo_'s Avatar
So I bought a set of k sport coilovers that are true type coilovers.I already purchased traction arms and camber arms from z1 to dial in my suspension but I still didnt pick up a set of toe arms.I heard about EMUSA from their LCAs but I haven’t heard anything about their other parts.Has anyone tried the toe arms or other parts from them? https://rover.ebay.com/rover/0/0/0?m...2F231804023386
Old Apr 30, 2019 | 08:24 AM
Blue Dream's Avatar
I drove ttrank's car solo
Personally I don't like the metal Heim joints because they can make a lot of noise. I had some SPL front endlinks with that set-up and got rid of them because I couldn't deal with the clunking and popping. I lived in Austin at the time where SPL is headquartered and they couldn't fix the issue. Also the ones you linked look cheaply made and I wouldn't trust them. Z1 makes a lot of great parts at a reasonable cost so I'd probably buy their version. Suspension isn't a system you want to cheap out on with parts IMHO.
Old May 1, 2019 | 06:24 PM
Ichiglo_'s Avatar
I’m kinda on a budget is it OKAY to use for example SPC toe bolts instead of buying a whole toe arms assembly? I’m going to be deleting my spring buckets and I currently have only camber arms and Traction arms I totally forgot to buy toe arms but I currently don’t have the money to drop on toe arms.Im not planning to go super crazy with alignment just a basic a basic alignment but I am going to be a bit low so that’s why I bought the rear arms
Old May 1, 2019 | 07:12 PM
Blue Dream's Avatar
Yep the toe bolts work just fine. You'll have to elongate the holes the bolts fit through which is easy with a Dremel and possible to do with just a metal file but it'll take a bit to do it that way. I dropped our sedan almost 3" and the SPC bolts were able to get me back to factory spec toe in the rear. Stillen camber arms got my camber back in spec as well.
Old May 1, 2019 | 08:02 PM
Ichiglo_'s Avatar
that’s great news for me! I got Z1 Camber arms and too bad Stillen bars are discontinued 🤧
Old May 1, 2019 | 10:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's just aluminum that you're removing so a file would definitely work but it will take some time with a rat-tail file. I used a right-angle attachment on a dremel tool, keep the speed at medium (or lower) with the right-angle attachment or you will burn it up.
obex26
May 28, 2012 11:04 PM
tolyD
Archived Sales
Apr 15, 2010 03:37 PM
idrive_MD
Sep 18, 2008 03:07 PM
turbomaxima
Archived Sales
11
Aug 11, 2006 10:55 AM
Disco_Monkey
Nov 27, 2005 06:06 PM
