G35 & G37, Coupes & Sedans
G35 fuel economy
Old May 19, 2019 | 11:38 PM
  #31
Hall Stevenson's Avatar
On the topic of fuel economy, here's two pictures from a road trip I made today. The two pictures are from ~10 miles apart showing it wasn't a case of going downhill or coasting in order to get "high" (for a G35 !) gas mileage.
Old May 20, 2019 | 01:17 PM
  #32
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Keeping in mind that's a totally different engine in your car.
Old May 20, 2019 | 04:07 PM
  #33
EPA ratings for the OP's car is 16/23 while mine is 17/23. As far as fuel economy goes, there's no real difference (1 mpg city ?).
Old Aug 4, 2019 | 07:43 PM
  #34
Xavier Bienaime's Avatar
Cat back, test pipes, k&n intake, short shifter
Get the vehicle up on jackstands and spin the wheels by hand with it in neutral to verify something isn't dragging.
Check your tire pressure (tpms might be malfunctioning).
Have the vehicle aligned (toe causes major friction and severely reduced mileage).
Pull and inspect the plugs, they tell you almost everything you need to know about the conditions in the combustion chamber.
Clean/replace your air filter, clean the MAF, inspect and clean the TB if necessary.
Inspect/clean the PCV valve.
OBD2 realtime scan the O2 sensors to verify they're cycling properly at idle and with throttle.
Remove/inspect the CATS with an inspection mirror or borescope for any melting on the media.
Smoke test exhaust system for leaks.
Run seafoam through the gas tank.
Perform an ECM and idle recalibration.
Sorry for the extremely late reply. My rear tpsm sensors are dead.... Would that effect my mpg?
Old Aug 5, 2019 | 04:08 AM
  #35
Scorpi0's Avatar
No. But u will get slightly better mileage with properly inflated tires.
iTzTeddy
Apr 13, 2016 06:18 PM
350z006
Engine - Intake/Fuel
Jun 8, 2012 01:18 PM
luxman
Oct 31, 2006 06:50 AM
