G35 won't start!!! Need some help?!
It's possible the pump is good but the pre-screen or filter, strainer, or whatever you want to call it mesh baggy over the pump pickup is contaminated with a bunch of ****. If the pressure is actually low I would pull and inspect the pump before replacing it.
Usually an OEM pump will either work or it will NOT work, there's usually not a middle ground where pressure is just low.
laratta
14
May 20, 2019 10:30 PM
sanchamp411
Dec 30, 2015 07:49 AM
RemmyZero
Aug 22, 2015 11:38 AM
G Thunder
V36 General Tech Questions
Dec 11, 2013 09:45 AM
