Unique Start Issue - To Start or Not To Start
Old Oct 15, 2013 | 07:07 PM
G Thunder's Avatar
I find this issue rather unique. I have a 2007 G35 S Sedan 6MT.
When it's warm/hot (75 degrees +)outside, I have to hit the Start button multiple times before it will turn over and start. However, when it is cool/cold outside (74 degree -) it will start up with a simple 1 touch.
To make clear when I hit the button without the clutch engaged it goes to ACC, everything works. Nav, radio.
When I hit the button with the clutch engaged and the times it doesn't start up, everything else comes on, A/C, lights, radio, etc.
Eventually it does start up, I have not yet been left stranded. However, I need to get this fixed before I do.
Please let me know if you need any further information.
Old Oct 15, 2013 | 07:10 PM
yosip1115's Avatar
Battery going out? how many miles? What have you recently maintained?
If you assumed we would ask for more info you should have given it, ha!
Old Oct 15, 2013 | 08:42 PM
vqsmile's Avatar
This could simply be that the switch makes better contact when it's colder. Next time it's warm, try being very diligent about pushing clutch pedal in all the way, wait a second or two, then press the button once and hold it firmly for a second or so. If it's simply a contact issue due to some subtle expansion and contraction on the contacts, then a casual 'stab' of the button might not quite make it. Give it a shot and see if it still repeats your symptoms.
EDIT: on second thought, it could also be poor contact on the clutch interlock switch down at the pedal.
Old Dec 11, 2013 | 09:45 AM
infinitidude's Avatar
Sounds like your push button is going bad. I've replaced 3 in the last few months for the same exact issue. When it gets really bad it is hard to turn the car off once it is running. Hope this helps
chinee
Jun 10, 2024 07:48 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
D1dphresh
Aug 7, 2015 06:10 PM
itschuckster
Jul 25, 2015 08:07 AM
