G35 & G37, Coupes & Sedans
"Check Engine Soon" - but no Limp Mode?
Old Jul 12, 2019 | 09:59 PM
Featster's Avatar
G35 sedan RWD
OK, so my '06 G35 sedan threw the dreaded P1759 & P1757 codes yesterday. Trans is clearly not functioning properly, took it to the shop today. The "Check Engine Soon" lamp is lit, but I don't think it's in Limp Mode. How can you tell if it's in Limp Mode? No other indicator lights on the dash except for the "Check Engine" and the usual. Thanks...
Old Jul 13, 2019 | 12:02 AM
Scorpi0's Avatar
My car has never went into limp mode ever with the check engine light on. I think limp mode is a myth.
Old Jul 13, 2019 | 12:10 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Only certain parameters will trigger limp mode, things like overheat or low oil or anything else that can damage the motor (loss of cam position, etc).
Those two codes are a 1st gear solenoid failure, probably the solenoid on the valve body gave up the ghost.
You will definitely know you're in limp mode because the engine won't rev above 2k and you can't drive more than 20mph.
Old Jul 13, 2019 | 01:54 AM
Scorpi0's Avatar
Drop a couple viagras in the gas tank. Thatll fix your limp mode.
yoyopol2000
Nov 20, 2022 10:52 AM
HenryLin
Aug 29, 2016 04:07 AM
sleedesigner
Apr 22, 2013 03:57 PM
G:Drive
Jun 28, 2012 01:06 PM
