G35 & G37, Coupes & Sedans
Cam sensor bank 1….
Old Feb 13, 2022 | 07:24 PM
Kpxl1023's Avatar
Ivory Pearl G35 coupe 6MT
Cam sensor bank 1….
So I got the usual reading on the dash for vdc slip & check engine lights on, turned out to be
code p0340 (bank 1) cam sensor. So I take out the 10mm bolt & unlatch the harness cable, but the sensor is lodged in & stuck in the housing. Anybody else run into this problem ?? I know most ppl have a tough time getting it off the harness, but mines an 07 with the new harness so that wasn’t much of an issue…any recommendations would be greatly appreciated
Old Feb 13, 2022 | 07:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's probably just the o-ring that's stuck, since you're trashing that cam sensor anyways just grab it with a pair of channel lock pliers and wiggle it side to side.
Old Feb 13, 2022 | 07:58 PM
Kpxl1023's Avatar
I already tried that…it’ll wiggle a bit but won’t fu**ing come out. It’s an 07 w/ 175k so it’s been in there for a hot minute
Old Feb 14, 2022 | 03:09 AM
Scorpi0's Avatar
Get a big flathead screwdriver and pry on it til it pops out.
Old Feb 14, 2022 | 03:58 PM
Kpxl1023's Avatar
Finally got that sob out after wrestling with it for a long *** time…do the check engine , vdc slip light, etc go away on their own usually ?? Mine are still on even after installing the new sensor ….
Old Feb 15, 2022 | 01:58 AM
Scorpi0's Avatar
Yes, they will go out eventually. Or u can reset it yourself and not have to wait for it. Easiest reset is to just disconnect the battery for a few minutes and hook it back up again.
Worin
Dec 1, 2019 09:03 PM
miketyler
Jan 31, 2016 09:40 AM
one2nite
Jun 2, 2012 02:16 PM
_jb
May 8, 2009 03:09 PM
