G35 & G37, Coupes & Sedans
G35 starts and then dies
Old Apr 25, 2024 | 02:26 PM
ethannnnnn's Avatar
g35 stock except test pipes and hr injectors
So I was chilling in my car and it just died wouldn’t turn back on has a rough idle then just dies. I tried to put gas in it Checked fuses. We also sprayed started fluid in the plenum and it started right up any ideas? I’m thinking fuel pump or regulator. The car also isn’t in the best spot to take everything off and go through everything and I don’t have money for a tow atm . Anything will help
Old Apr 27, 2024 | 10:23 AM
Urbanengineer's Avatar
Usually with this platform it’s cam crank sensors when you don’t get a code at first.
if it doesn’t prime fuel pump at key to on (but not start) then it’s definitely fuel related.
Old Apr 29, 2024 | 01:52 PM
ethannnnnn's Avatar
yea so I did that already replaced both finally got a code reader to it and I’m currently getting p0113 and p0335
Old May 1, 2024 | 09:16 PM
MaLPoPieS's Avatar
Jaguar XFR-S
P0335 is Crankshaft Position "A" Circuit Malfunction and that will be your main issue. The P0113 is probably a dirty MAF sensor. But the crank sensor will need replacing. Check the plug to it, mind need that also since they like to bake crispy..
lucid215
19
Oct 19, 2019 03:51 PM
Calipat916
Jan 17, 2016 03:12 PM
jw0595
Nov 30, 2007 12:42 AM
