G35 & G37, Coupes & Sedans
Gas tank problems? Geez!
Old Feb 17, 2006 | 09:47 AM
nnkfws333's Avatar
I had this problem, first they replaced some gaskets, then they tried it again, finally they just gave me a new gas tank and so far on 1000 miles no problems at all.
Old Feb 17, 2006 | 10:32 AM
giddyup69's Avatar
there is a tsb out on this here:
http://www.infinitihelp.com/Ownershi.../ITB05-031.htm
print it out and take it with u. i had the exact same problem on my '05. it is a very huge nuissance.
Old Feb 27, 2006 | 06:54 PM
JediRacer's Avatar
Angry
I took my car to the dealer (see above post) and they said they cannot replicate the problem. I've been to 3 different gas stations, and the problem with filling the tank happened at all three stations. The dealership is claiming that the "new" pumps sometimes carry remnants of gas fumes in there that signal the pump to shut off, so the problem lies with the pumps and not my car. The dealer only put in $1 worth of gas though.. probably not enough to assess the situation. Arrrrrrgghhhh
Old Feb 27, 2006 | 09:36 PM
03 6MT's Avatar
I just started experiencing the same problem about 4000 miles ago. I got to a point where I could only fill to a 1/4 tank before shutting off. It's gotten better in the last few weeks, but now when I fill up, my needle does not go all the way to F. Guess I need to schedule an appt as well.
Old Feb 27, 2006 | 10:28 PM
mephistomyhero's Avatar
Wow, you guys sure resurrected this from the GRAVE! I can see why those posters in June of 2003 were posting this but since there is a TSB on this, I'm wondering why you guys bringing this thread back to life
Old Feb 27, 2006 | 10:38 PM
GX9901's Avatar
My wife's '04 FX35 also has this problem, and it seem to be worse than my coupe's. Pretty annoying. Something about Infiniti gas tanks I guess.
Old Jun 3, 2006 | 08:13 AM
PeaRLyWHITE's Avatar
if you have a g35 why put costco gas in it???????? come on..... at least put premium
Old Jun 3, 2006 | 11:26 AM
JBKFizzle45's Avatar
well good to know im not the only one with this prblem! I noticed this happenening a coupe times but onyl at a Hess station - I havent had this problem anywhere else. I noticed that lifting the nozzle and squeezing at half strength kind of alleviates the issue at times - but this has only happened twice in 6k miles so its not that much of an issue
06 DG Coupe 5AT
Old Jun 3, 2006 | 11:31 AM
boxa87's Avatar
the same thing happens to me hear in florida all the time..you have to pull the nozzle out a little bit if its to far in something touches the spring that causes it to shut off
Old Jun 3, 2006 | 06:19 PM
jello_1955@hotm's Avatar
I just got my '04 coupe back from the dealer with the same problem. Of course, the typical thing happened -- they filled it up without a problem.
Old Jun 3, 2006 | 08:00 PM
B33R's Avatar
I read this trick on these boards and it worked really well for me with pumps that were causing me trouble. Try rotating the handel of the pump a 1/4 turn clockwise then pump. Turn it to like 8/9 o'clock. It should fill and turn off when it is full.
Old Jul 7, 2006 | 02:06 PM
MikeVG's Avatar
I have had this same problem but it's been intermittant, unfortunately it has been happening more often than not, so i'm glad i found the TSB and am going to get it to the dealer and get it hopefully taken care , BTW i tried just about every possible combination of ways to fill the tank, turn the nozzle, hold the spring loaded filler back, hold the lever 1/2 way...... none of them worked for me.
Good luck to everyone ,MikeVG
Old Jul 8, 2006 | 07:20 PM
L454's Avatar
Here's a link to the TSB
Old Jul 9, 2006 | 01:55 AM
shellguy05's Avatar
Do what I did, move to NJ where someone else has to fill up your tank for you, and just keep telling him it isnt full, untill he gets enough in there to get it full, and while your waiting you can finish that report due on Fri, or weave a basket, or maybe even learn Japanese.
mtlruss
Dec 20, 2015 01:51 PM
Jnm07
Sep 5, 2015 01:16 AM
Patrick Bovee
Sep 4, 2015 11:57 AM
06gtfanatic
Aug 31, 2015 03:19 PM
Jroc2017
Aug 16, 2015 07:16 PM
