G35 & G37, Coupes & Sedans
Why does infiniti say to use conventional oil and Nissan uses synthetic
Old Oct 15, 2005 | 10:11 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by imalazeeass
btw, its INFINITI
I fixed the mis-spell.
C.
Old Oct 17, 2005 | 11:46 AM
stl_ls1gto's Avatar
The key is when you change the oil. You can use regular oil, and as long as you change it every 3000, you will never realize the benefit of the synthetic. Your engine will run over 150,000 on regular oil just fine as long as you keep up your preventitive maintanence.
Old Oct 27, 2005 | 12:14 PM
FrizzleFry's Avatar
that is correct. am i the only one here that changes their oil every 4-5k? btw, the recommended OCI is 7.5k on dino. I also buy my filters from Nissan rather than Infiniti.... it's $2/filter difference for the same part.
My oil changes cost $10. Now some may say "well you should spend the money, you already spent so much on your car." I'm no cheapskate. I'm just more practical about spending. Why spend more when it's not necessary? Using a bottle of synth would be $20 for 5 quarts mobil 1 and $5 for the filter.. or if i went w/ mobil 1 filter $10. So $30 some may be paying more for synth oil. Is using mobil1 going to make that much of a difference? well i guess only time will tell.
Old Oct 27, 2005 | 01:07 PM
ARH_twilightblue's Avatar
Although modern dino oils provide pretty much the same protection as synth. they do not keep the engine internals as clean as a synth would, even at 3000 mile intervals. This, of course, is irrelevant if you don't plan to keep the car a long time.
Old Oct 27, 2005 | 03:00 PM
Pwoz's Avatar
Originally Posted by bubbletea 4 me
u can put anything into a civic and it will still go like when its new. thats what hondas are for.. they are great everyday car that never breaks down and u can use the cheapest everything on it, and it will still go great!
as for the Z/G, better use something good..
I saw a video, can't recall where now though, with a honda that the guy put water in instead of oil (It was a really old honda that was ready to be scrapped) and sat there revving it off the rev limiter and it kept going, albiet smoking a lot.
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
mostestG35
13
Aug 15, 2015 05:56 PM
NemesisGee
Aug 11, 2015 07:10 PM
Team STILLEN
Aug 10, 2015 08:17 PM
