G35 & G37, Coupes & Sedans
Service Engine soon
Old Nov 17, 2005 | 06:11 PM
GfortheCPE's Avatar
Service Engine soon
So my service engine soon light is on. All fluids good etc.
Seems to be running fine, good temp good pwr etc.
I called infiniti and they say that only they can reset it NO MATTER WHAT even if it was just the gas cap not being fully tightened.
The car has 30k miles if that has anything to do with it.
I think it is stupid if I seriously have to drive 2 hrs one way to get the light reset even if its someting silly like gas cap.
Anyway, any information would be great!
Old Nov 17, 2005 | 06:59 PM
Msedanman's Avatar
O.F. Administrator
Try an ECU reset yourself.....they're found here---https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
C.
Old Nov 17, 2005 | 08:55 PM
DaveO's Avatar
So my service engine soon light is on. I called infiniti and they say that only they can reset it NO MATTER WHAT...
I suspect you've received a large dose of BS from your local friendly Infiniti dealer! Any good code reader or scanner should be able to identify the code, clear it and the SES light as long as the source is no longer present.
DaveO
Old Nov 18, 2005 | 12:09 PM
giddyup69's Avatar
Old Nov 18, 2005 | 09:32 PM
GfortheCPE's Avatar
yeh figured infiniti rep was full of ****
went by autozone, guy had an obdII reader
code was p0102
books says can be one of 4 things all involving either loose or cracked hose causing vaccum leak or a loose throttle body or something else pertaining to intake.
Im gonna inspect tomorrow in daylight see if I see any hoses loose, anyone had similiar issue?
Old Nov 19, 2005 | 11:10 AM
DaveO's Avatar
code was p0102
Diagnostic Trouble Codes P0102, P0103 - MAF SENSOR
Old Nov 19, 2005 | 03:30 PM
GfortheCPE's Avatar
looked around engine compartment didnt see anything...
cranked her up, light is no longer on...so ima wait a few days be sure then cancel my apointment
Old Nov 19, 2005 | 10:03 PM
TINMAN's Avatar
Dude..your your engine will explores if you don't take it to the dealer j/k
stupid as it sound,if the gas cap loose it'll give you the service light.samething happen to BMW.so just for the hell of it,check that first before taking step 2
Old Nov 20, 2005 | 10:16 AM
GfortheCPE's Avatar
Ok, a new observation.....I could just be im paranoid now and noticing really minute things since my SEL came on a few days back but...
This morning i took the car for a spin, SEL is still off (whoopie) I did a run through 1st and 2nd to about 6000rpm and after I had let off I could smell a slight burnt smell that lasted about a 1/4 mile and it went away.
Later i ran from 3k in 3rd to 5500 in 4th and shifted to sixth and again smelled a slight burn smell for a few seconds.....
Anyone ever observed this?
Im not sure what it could be really, im not slipping the clutch enough to burn it I doubt only other thing is at high rpms if more fuel is being dumped cause of variable cam timing stuff then suddenly I let off throttle and it doesnt immediately slow fuel rate could I get the smell from excessive fuel dump??
Thanks again for any input
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
