Summer tires in cold weather
From reading the forums..I have heard that the stock summer tires start losing traction as the temperature lowers. At 10 degrees I can only imagine that the tires will not perform very safely. However, as long as the roads are dry and you take it easy on the throttle, I think you should be ok. I would, however, think about investing in some all seasons or even winter tires. I did, and they perform excellent in the cold weather and snow.
LOL If you want to do donuts now is the time
....seriously, grip will be greatly reduced...be carefull.
You won't feel them loosing grip either, they'll just go on you.
Originally Posted by Atooraya
It's 10 degrees here in chicago and -2 wind chill.
the road's are dry now, but how bad would it be to take my G out with the stock 19's and the 40 profile tires
For your own, and everyone else's safety, don't go out in cold weather with summer rubber on.
C.
$870 for 17 rims and tires from Tirerack.com, just in case you find your 19's aren't keeping you safe.
JM2C But it's not only that....your actions could impact someone else.
i kinda want the stock 18's that come with the auto g's
Running summer tires for extended periods in temps below 50 degrees will significantly reduce their life. The compounds in the tire will harden and it's irreversible. Often times the summer tires will begin to chunk.
As for driving in sub freezing weather with any tire, if Chicago streets are anything like Kansas City streets and have a film of dried de-icer, it can be flat out dangerous. It is terribly easy for me to whip out the tail on 5AT sedan with the littlest provocation or light them up threw 1st and peg the limiter in a split second. These are dry streets too. You have to be careful and I wouldn't suggest turning off the VDC. My G has all-season rubber too.
I got these rims:
http://www.tirerack.com/wheels/Displ...atin+Sil+Paint
And these tires:
http://www.tirerack.com/tires/Sizes....l=Graspic+DS-2
The tirerack guy suggested the 225/50/17's when I told him I didn't want a staggered set up (so I can rotate all my tires). These Graspics aren't performance winter tires, so they are a little squishy and reduce the performance handling of the car, but for the winter I just want to get places safe and sound, and when the summer rolls around the 19's will go back in when I do autoxing and a track day or two when I can. I'm on a budget so saving the couple hundred by getting the Graspics instead of more expensive performance winter tires was important to me.
And these tires:
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
