G35 & G37, Coupes & Sedans
Weird metallic noises?
Old Dec 23, 2005 | 12:41 PM
TonyK's Avatar
Just wondering if anyone had the same things I've been noticingon my car:
1) brief metallic creak when accelerating from stop
2) random duration, intermittent metallic squeal during driving - this one is pretty puzzling, since I can't localize the noise, and it happens regardless of braking or turning or acceleration.
Anyone?
Old Dec 23, 2005 | 01:51 PM
giddyup69's Avatar
never heard anything like that on my coupe. what year/model do u have? may help others diagnose your problem better.
Old Dec 24, 2005 | 01:28 PM
ARH_twilightblue's Avatar
Your #1 description sounds like the typical clicking rear axles issue. If it's coming from the rear print this out: http://www.infinitihelp.com/Ownershi.../ITB05-002.htm and take it to the dealer. They will fix it for free. I am not sure about your #2 issue though...
Old Dec 24, 2005 | 04:25 PM
TonyK's Avatar
I've got a 2004 5AT coupe. And problem # 2 only started on Thursday. I have to admit, it freaked me out a bit.
Old Dec 24, 2005 | 05:56 PM
1dannyboy's Avatar
ARH is correct... the rear axle bolt may need to be tightened... if it is more severe they may need to replace the bearings and bolt.... This should fall under warranty work... I had the same issue on mine...
First time was on the rear passenger then it happened on the rear driver side... the dealer had no problem fixing the issue...
The metalic squeaking may be the breaks... there is a "early warning" the pad wear sensor that makes a terrible sounding noise when your breaks wear down to a certain level.... you may have plenty of break pad left but it is there to warn you to have them checked...
The pad wear sensor is basically a thin piece of metal that is adjustable but it is there to warn you to have your breaks checked... you can adjust it yourself, but I am sure you dealer would have no problem looking at the problem
Old Dec 24, 2005 | 06:39 PM
G35SHAWN's Avatar
As crazy this may sounds, for some reason i get that same sound once in a while & i am 95% sure it comes from the passenger side seat belt.
Old Dec 24, 2005 | 09:04 PM
borahatch's Avatar
As others have said, the first thing is from the axle. You don't even need to print anything out, just take it to the dealer and say your axle clicks when pulling off from a stop. Its very commone and they will know what you are talking about. I took mine in to Riverside Infiniti last week and had my clicking axle fixed.
Anyone?
Old Dec 25, 2005 | 12:30 PM
Andy2434's Avatar
My rear axle bolts came in last week. Had them replaced and everything seems find at the moment. That was a very annoying noise when throttling out of 1st and 2nd gears . . . I trust that it stays away for good.
Old Dec 25, 2005 | 03:06 PM
MechEE's Avatar
Yes, the passenger side seatbelt buckle hits the side of the car sometimes if it's not mounted inside the holder on the passenger seat! A bit annoying.
Old Jan 19, 2006 | 07:53 PM
twitch's Avatar
sorry to bring this post up from the past but doing a search led me to this.
Does ANYONE have an idea on how to keep the passenger side seatbelt buckle from hitting and tapping on the door? I've tried all different positions with the "holder" and it still contacts the door.
Old Jan 20, 2006 | 12:48 AM
EZZ's Avatar
EZZ
Turn up the music. or just belt the thing in (even though nobody is there).
Old Jan 20, 2006 | 01:07 AM
Andy2434's Avatar
Simply lower/drop the seat belt retaining arm.
Old Jan 23, 2006 | 11:13 PM
rpc's Avatar
rpc
Nice. When I took my car in, the part was on BACK ORDER for 5 weeks. So I was chillin a G35 Sedan for the entire time. Luckily everything is under warranty and it didn't cost me a dime. What would have been better is if they paid for my gas too. Oh well.
Old Jan 25, 2006 | 09:30 PM
ZLUJ's Avatar
Mmhm...
edit: disregard my post.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
