Homelink openin garage by itself :X
Originally Posted by k67p67
It don't think it disables the rolling code technology. Who's going to sacrifice home security just to be able to use their Homelink? I believe the Homelink learns the rolling code algorithm.
If it was really learning the code-rolling algorithm, than I shouldn't have had a problem getting it to learn the code for the gate, in my brother-in-law's gated community.
Most garage door openers have two settings, one for tension (how hard the door bottom presses down to the floor) and sensitivity (how easily it reverses if it feels an obstruction on the way down). If these are both set fairly high, the door can sit there 99% of the time just on the verge of reversing. All it takes is a change in temperature, some thermal expansion/contraction, and the door reverses and goes up, seemingly at random. Back off the tension and/or sensitivity settings and see the problem improves.
on
1 Post
if u find u can't reset the car's homelink ... why don't u just reset it from the garage door's side? i did this on mine when my cars got stolen. usually it's just a matter of holding the button on the garage door motor down and then re-programming your transmitters. check your manual. if u don't have a rolling code on your garage door motor then u should have some dip switches to select a different transmit code... again, just check your manual.
Originally Posted by Sim
which auto button are u referrin to?
U guys shud see how crazy its drivin my parents and older brother, it opened the garage at 1am last nite, my brother and I heard it at the same time and woke up to close it, rite now we unplug the garage at nite (forgot to last nite).
Anyways, like I said, Ive resetted the damn thing I dont kno how many times, if the dealer says tuff $hit like I expect them to, I guess Imma hav to find away to totally clear out the garage opener unit itself, or somethin, Im not a handyman, Imma end up breakin it
But in any case, Im 100% serious about it lol POSSESSED!
Did you try clearing & then programming a different button?
Originally Posted by avs007
I don't think so. How does the homelink learn the algorithm? It's not like the transmitter sends the algorythm to the homelink. The learn button on the garage door opener, is so it can learn the fixed code from the homelink (which effectively disabled your rolling code).
It started happenin the day after I first programmed the homelink, which was a few days after I bought the car (mid dec 05)
This weekend Imma try reprogrammin, erasin, etc, see wat happens, otherwise Ill wait for my appt on monday for service so they can tell me that I belong in a loony bin
