G35 & G37, Coupes & Sedans
Spacer Quiz
Old Mar 18, 2006 | 12:02 PM
vt_maverick's Avatar
Question Spacer Quiz
I'm currently running a stock 03 6MT G35 Coupe and am looking to put on a Motordyne spacer as a first cheap upgrade. I've found a lot of info in other threads on this topic, but there seem to be some conflicting opinions. So help me clear it up.
Here are my 6 choices (keep in mind that MREV is not an option since I do not have the "revup" engine):
1. Motordyne 5/16" Basic Spacer
2. Motordyne 1/2" Basic Spacer
3. Motordyne 5/16" ISO Thermal Spacer
4. Motordyne 1/2" ISO Thermal Spacer
5. Motordyne 5/16" Copper ISO Thermal Spacer
6. Motordyne 1/2" Copper ISO Thermal Spacer
I'm looking for opinions with regard to any or all of the following criteria:
1. Noticeable power difference between 5/16" and 1/2" spacers
2. Value of thermal or copper thermal technology over basic spacers
3. Effects on fuel economy - increase, decrease, by how much...
4. Do I have to cut or remove the stock engine cover
5. Difficulty of installation for a novice
6. Cost of installation at a shop or dealership
7. Warranty issues
Welcome any and all opinions. Thanks in advance!!!
Old Mar 18, 2006 | 05:19 PM
OCG35's Avatar
7. Warranty issues
I would suggest 1/2" for your application... I have it and am happy. If you had newer (Rev-up) 5/16" would be the choice... the OEM cover will fit - I suggest you invert the grommets. Or, do as I did and get a 1/2 cover (350Z) - you can trim to fit as well (I did this to a CF cover but don’t have pics right now) - fuel economy??? Don’t know - I drive spirited frequently so I am not too concerned about MPG (I avg 17-18 AT) It's not difficult to install, Tony has clear concise installation instructions. Warranty should not be an issue - many of us have the spacer and I have heard of no problems... It is easily removed to stock in case you need to take in for warranty. I have had my car to dealer for scheduled maintenance several times since having the spacer - no problems.
Hope this helps... There is a TON of info out here regarding ME spacers... search for it and you will have all the info you need to make an informed decision.
Old Mar 19, 2006 | 02:30 PM
Thanks for the info. I'm definitely going with the Copper ISO Thermal, but I'm still trying to decide between the 5/16" and the 1/2". I've done some more reading on this forum, and checked out the dynos on MD's website. I think I'll probably be happy with either one, so I'm trying to think long term.
I'm considering getting a TT or supercharger down the road, so will both spacer's be compatible? Or would I even want/need to have the spacer at that point?
Thanks.
Old Mar 19, 2006 | 03:59 PM
Canadian's Avatar
Canada, eh?
i dont want to hijack your thread, but i would like to know if i got the 1/2 spacer, will it fit 100% with my engine cover and will i have to move/remove ANYTHING in the engine bay to get it to fit?
Old Mar 19, 2006 | 07:33 PM
haze's Avatar
according to MD's site, with the 1/2 spacer the stock engine cover will not fit.
actually, i got a relating question as well. Which of the following will be most compatible with FI system?
Old Mar 21, 2006 | 09:30 PM
OCG35's Avatar
stock cover will fit with 1/2"... talk to Tony directly and he'll tell you the same thing. Mine fit... The reason I went with 1/2 cover is to keep the plenum cooler - I have ME coolant control valve and holding in plenum heat with the full cover would defeat it's purpose... there are several informative threads out there... also Sport Z mag has had some write ups... just search and you will find all you need to know to make an informed decision.
Old Mar 24, 2006 | 10:48 PM
Chrlesmd's Avatar
Hey guys, newbie here; atleast to the G35 forum. Got my 04 Silver G35 Coupe last weekend and I love it. Definately want to add the spacer & Z-tube, but not sure about the increase in sound. How much louder is the 1/2" over stock?
Old Mar 25, 2006 | 11:20 AM
Hydrazine's Avatar
Its definitly there. At least for me. Its both louder and deeper.
Some people say they cant hear it but the majority say they can.
I can hear them. ...I like the sound.
Old Mar 25, 2006 | 01:17 PM
Chrlesmd's Avatar
I definately want to get it. Just not sure which one.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
