G35 & G37, Coupes & Sedans
Factory anti-theft? Alarm?
Old Mar 21, 2006 | 01:07 AM
G35 Mass's Avatar
03 5at here.
Ok. So when the dealer was trying to program a new key to my car, they somehow set off an alarm, which consisted of at least a horn pulse, I dont remember if any lights were on. They said it had something to do with the key being used in the door to turn on the alarm... This was the first I had seen of any alarm.
But now I cant get it to come back on. Not using the remote, not using the key in the door.
Does my vehicle have a factory alarm? There is an LED in the dash area near the clock / climate display. Ive tried everything I can think of to get the alarm to sound but can not. Meaning tried everything to turn on the alarm, reached in and unlocked the door from the handle and opened, etc....
Old Mar 21, 2006 | 03:50 AM
limeg35's Avatar
Its just an panic alarm, just press and hold the red botton for few secs then horn will go off and lights should flash was well.
Old Mar 21, 2006 | 04:43 AM
G35 Mass's Avatar
How did the dealer get this to happen? At that time I didnt have any remotes....
Old Mar 21, 2006 | 08:37 AM
giddyup69's Avatar
just lock your car up with the windows down. wait like 30 seconds and unlock the door from the inside... the alarm should now be going off.
Old Mar 21, 2006 | 09:34 AM
Steel Blue's Avatar
Is there anyway to add a shock sensor to the oem alarm?
Old Mar 21, 2006 | 09:44 AM
G35 Mass's Avatar
30 sec? Ill try that.
The LED On the dash never flashes...????
Or is that for the james-bond like oil slick delivery system I have not yet tried???
Old Mar 21, 2006 | 10:11 AM
giddyup69's Avatar
i think when u lock the doors the light should go solid. then after 30 sec the alarm should be fully active and the light begins to flash.
giddyup69's Avatar
yes... there are many references on these forums for adding a shock sensor.
simple forum search gave me this handy link:
http://g-owners.com/article_read.asp?id=43
Old Mar 22, 2006 | 01:11 AM
G35 Mass's Avatar
Negative on the light and reaching in and opening....
Is there a procedure for disabling the alarm?
Old Mar 22, 2006 | 01:17 AM
speedracerg35's Avatar
your solid light should start blinking after 30 seconds or so, telling you that the alarm is armed. if your l.e.d. never starts blinking, you have a problem. you can try basically the same thing as you tried before...turn the car off, remove the key from the ignition, arm the alarm with the remote while sitting in the car. if and when your l.e.d. starts blinking, unlock the door manually and try to exit the car. your alarm should go off. if your l.e.d. does not blink, you need to take your car in.
Old Mar 22, 2006 | 03:28 AM
G35 Mass's Avatar
yay yay yay i get to go back in!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
