Please Help Me, My Car Went Into Limp Mode Whats Going On, Please Whats Going ON?
Old May 12, 2006 | 12:26 AM
mwarsh1's Avatar
hello everyone, i took my car to a body shop for them to take off my steering wheel, they take it off and replace it with a different one, i go to start my car, and its making noise, and shaking, whats going on, is it in limp mode? what is going on, its really scary?
PLEASE TELL ME WHATS GOING ON? IT SOUNDS LIKE THE CYLINDERS ARE MISS FIREING.
Old May 12, 2006 | 11:52 AM
safil's Avatar
Do you have the car or does the bodyshop? If you have it, the only thing I would try first is a ecu reset. The easiest way for you to do it is to disconnect the neg. and pos. battery cable and touch them for about 5 seconds. Then, connect them again, neg. first then pos. If the car is at the shop, see if they have a scanner. That's probably gonna be the only way to diagnose the problem, other than looking around for any sensors that aren't connected. It sounds like an electrical or sensor problem and without hooking up the scanner and telling me the code, it's hard to say exactly what's wrong with it. But, from just changing the steering wheel to another? That's sounds weird. Don't know how that could effect your engine management sensors! Good luck and tell us what happens! By the way, sounds like the crank position sensor or timing camshaft sensor but, don't see how that would get affected with a steering wheel change. They must of touched something else. Either way, good luck!
Old May 12, 2006 | 02:54 PM
Philly_G35's Avatar
It may have something to due with the airbag sensor. It's just a guess, but the car may go into limp mode if there is a problem with the sensor.
Old May 12, 2006 | 04:14 PM
safil's Avatar
Could be but, I don't think so. Anyway, if it is, by resetting your ecu it should solve the problem...
Old May 12, 2006 | 05:49 PM
OCGsedan's Avatar
dude - how in the world would anhyone be able to diagnose ur issue with that?
take it back to the shop & have them double check their work to ensure they put everything back together right.. if it's still jacked up- take it to the dealer.
i wouldn't go messing around w/ anything other than an ecu reset as u may make things worse. good luck
Old May 12, 2006 | 07:12 PM
marchesano's Avatar
www.g35tt.com
+1, Does your airbag warning light blink on the dash? What about the VDC light as well?
Old May 12, 2006 | 11:45 PM
safil's Avatar
I doubt he's gonna try to fix it himself other than an ecu reset. He's probably just curious as to what is going on with the car. Wouldn't you be?
Old May 14, 2006 | 01:25 AM
NYCG35's Avatar
G SQUAD
You're right Fil,..
hey it never hurts to ask
Old May 14, 2006 | 12:53 PM
safil's Avatar
Thanks!!!
Hasanbaloch
Feb 29, 2024 08:45 PM
hdmark
Apr 29, 2019 04:31 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
Cskeet
Jul 21, 2015 05:48 PM
