proper idle
Old May 24, 2006 | 04:30 PM
diablo1356's Avatar
proper idle
ok i posted recently that i had my ses light go on and a slightly higher idle after i got a oil change and cleaned the throttle body etc...ok anyway i did the pedal reset, the whole relearning procedure and everything seemed fine...my car used to idle at like 300 rpm...then after the oil change was at like 900-950..then after the reset was at like 650...ok so everything was ok till i drove my car a little fast...the stupid SES light comes back on so i take it to advancedautoparts to have them check the code...their stupid comp wont work with the g but i explained to him what i had done and he just told me to disconnect the negative battery terminal and let it completely reset..so thats what i did...no ses light for some time but my rpms are back down to like 300 rpm???...thats not a normal idle is it??..i mean the car runs fine other wise and i never really payed attention to the idle...i just figured after the intake, spacer, headers, and dual exhaust the idle was gonna be lower...anyone have some comments on this??...im sorry for the long post but im just concerned...i hope my idle doesnt drop to like 100 after my grounding gear install!!...
Old May 24, 2006 | 04:50 PM
budzync's Avatar
mine idles at 300 rpm also. just ordered Gordgee's grounding gear and i do not expect my idle to change any after i install it.
Old May 24, 2006 | 06:08 PM
codeflux's Avatar
have your car checked by a dealer. the pedal-reset method is perfect for restoring correct idle. you can also do more procedures outlined here:
http://www.technosquareinc.com/350reset.htm
as far as SES light goes, it could be as easy as having a dealer replace an O2 sensor. should be a TSB out for that. have them check it out.
Old May 24, 2006 | 08:43 PM
budzync's Avatar
so i am looking at my tach on the way home and think.........um.....thats 650 rpm i idle at, not 300 rpm, as it starts at 500 rpm and each dash represents 1 rpm........i really need to re-think what i type.....oh well......back to lurking
Old May 24, 2006 | 09:17 PM
Msedanman's Avatar
O.F. Administrator
650 is good bro....but it'll vary between 500 and 700 at times.
Sounds like you're ok.
C.
Old May 25, 2006 | 08:06 PM
Chrlesmd's Avatar
I thought each dash was 200 rpms...my G35 seems to sit in gear at right around 300-400 rpms. I recently changed my air filter, and the car doesn't seem as quick as before.
Old May 25, 2006 | 10:14 PM
99atlantic's Avatar
you cars can't idle at 300, esp. if you have headers........that's too low and would stall out
mine used to idle at 600, then after headers and **** no widles at 800.
adding headres and breathing stuff will generally bump idle up, not lower it.
Old May 25, 2006 | 11:39 PM
lightforce18's Avatar
After installing a 5/16 spacer. Pop charger/ztube and grounding kit. I noticed my idle was higher too. I did a pedal reset too.
No matter if im in Neutral or Drive its the same idle now. Weird
Thebaws11
Jul 2, 2021 11:36 AM
Vqalexisz
Oct 14, 2015 12:48 AM
vamarris
Sep 26, 2015 12:56 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
