Sattelite radio question
Old May 28, 2006 | 08:57 PM
jtuner77's Avatar
So I just bought a used 2003 g35 coupe 6sp mt and I was wondering about the SAT button on my radio. Is the car equiped with the parts for satellite radio and how do I go about setting up that to work???
Is it Siruis or XM??? If it just has the button for it how do I get the proper equipment to get it to work and if has all the equipment for it to work how do i get in contact with the satellite radio provider to get it connected???
Old May 28, 2006 | 09:10 PM
Mike_Deezy's Avatar
First off, to find out if your car is prewired for SAT, look at your VIN:
Sedan VIN: 321894 & higher
Coupe VIN: 210827 & higher
Not sure if you have a coupe or sedan, but based on the VINs above, if your last 6 digits are higher then it is prewired for SAT. If you are prewired, all you would have to do is purchase the SAT tuner, either Sirius or XM, your preference. I personally have Sirius.
Old May 28, 2006 | 09:29 PM
jtuner77's Avatar
mine ends in a 207--- so i take it i am screwed??
Even if it is prewired do you still have to have a siruis display or can it display through the stock headunit???
Old May 28, 2006 | 09:34 PM
Mike_Deezy's Avatar
looks like you're going to have to buy the wiring harness as well. if you really want to make sure that you are or not prewired, you can look in your trunk next to your spare. if you are prewired there will be an unused wiring harness right next to the bose amp if you have one. i would suggest you do this before buying the wiring harness. but whether or not you are prewired, it will show on the stock hu.
Old May 28, 2006 | 09:36 PM
jtuner77's Avatar
On my stock headunit it has a SAT button so does that mean I am prewired???
Old May 28, 2006 | 10:25 PM
Mike_Deezy's Avatar
No it doesn't, check for the harness in the trunk.
Old May 29, 2006 | 01:12 PM
Fourlix's Avatar
How hard is it to install a sat radio? I see them on everything g35.com for about $260. Mine's an '06.
Old May 29, 2006 | 02:31 PM
Infiniti514's Avatar
It fairly simple. Look for a DIY guide here or on 6MT.net. For the antenna, to make things easier, I mounted mine inside the car on the rear deck lid, or whatever its called, between the speakers. Its much easier than mounting it on the roof.
Old May 29, 2006 | 10:33 PM
Mike_Deezy's Avatar
The install in very easy, I did the install on my car myself.
Frostbite91
Aug 20, 2015 07:20 PM
Frostbite91
Aug 12, 2015 05:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
