Click, Click,......Click on 6MT(not usual noise)
Old Sep 25, 2003 | 12:27 PM
GforceI's Avatar
G SQUAD
Ok i just noticed this the other day. When I first get in the car and go into reverse as soon as I start to move the is a distinctive clicking sound, usually 3 clicks 2 fast and one a second later. It seens to happen when I go in first too. I have no idea what it is. I think it's comming from the tranny but not sure. It seems to go away after I have been driving for a little bit. Normally I wouldn't ecare about stuff like this but I know some people have had problems with their tranny's and I want to make sure this thing is ok b4 my warranty runs out. Preventative mantience type deal if you know what I mean. Any way does anyone else have this noise. I only hear it with the windows down.
Just wondering if it's at all common. Thanx guys.
P.S. It's not the usuall tranny noise that everyone hears I know about that this one is when I first start moving.
Old Sep 25, 2003 | 01:01 PM
Kozlikracing19's Avatar
Re: Click, Click,......Click on 6MT(not usual noise)
I had that clicking sound on my 96 avenger. AT
Right now with my G35. I think it's nothing big, but you should just take it to the dealer anyways.
Later
Old Sep 25, 2003 | 01:07 PM
RaySur350GT's Avatar
Is it coming from you rear right side? A lot of 350Zs and G35Cs are having this problem. There is a TSB on it so you can take it to the dealer and they will fix it under warrenty. It should be the loose axle bolts TSB.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Sep 25, 2003 | 02:36 PM
GforceI's Avatar
G SQUAD
Yeah I have to take it in anyway for a window regulator so i'll mention it to them then.
Old Sep 25, 2003 | 03:31 PM
weslutes's Avatar
It's probably the abs system,the clicks are pretty loud.You should hear four clicks for each wheel every time you accel/brake.
Old Sep 26, 2003 | 12:46 PM
mchristsen's Avatar
I had a simmilar problem with s clicking sound from the right rear of the car whenever the car would start moving (forward or back). There was a loose bolt on a suspension bracket. It is a common occurance (thus the TSB). Dealer fixed it no problem. This could be the same problem.
I also had the window regulator changed for the drivers side window. Hehe
Good Luck.
Mike.
2003 6MT Coupe Black/Graphite/Prem./Nav/Aero
1994 MR2 Turbo 5MT Black/Prem.
magnetism80
Feb 1, 2019 10:00 AM
mtlruss
Dec 20, 2015 01:51 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Frostbite91
Aug 20, 2015 07:20 PM
