Passenger side window not coming up
Old Jul 16, 2006 | 02:32 PM
MikeVG's Avatar
I have been having a problem that just started, i put the right side window down and then will not go back up unless i slam the right side door shut then it goes up like it normally would. Any one else have this problem?
Old Jul 16, 2006 | 04:03 PM
diablo1356's Avatar
i had a problem with the window going up and then coming back down half way but only when i used the auto function...the best thing i would suggest is to just get the door panel off and use the window motor reset button...heres the link on getting off the door panel http://www.thegsquad.org/DIYS/Coupe%...%20removal.jpg
and heres the reset procedure: https://g35driver.com/forums/showthr...+panel+removal
its on the last page at the bottom...and as for the DIY just enlarge the pics by clicking on the box at the bottom right of the pic..its called landscape i think..anyway i did the procedure and it worked..my window is fine and it took me like 30 min...pm me if you need more detailed instructions...
Old Jul 16, 2006 | 11:27 PM
jclit's Avatar
its the motor, i had the same exact problem. I had to slam the doot pretty hard for it to go up...I would recommend to change it asap, because itll stop working completly...
Old Jul 17, 2006 | 12:13 PM
o2bmj23's Avatar
Yeah take it to the dealership. This happened to me about a month ago, it was the window motor. The dealership replaced the motor for free. So that's what I would if i were you cuz it was a big pain in the ***. I would shut the door to go somewhere and the damn window would roll down by itself. That totally sucked.
Old Jul 17, 2006 | 05:46 PM
filanj's Avatar
+ 1
Old Jul 17, 2006 | 10:47 PM
MikeVG's Avatar
OHHH CHAD @ Infin of RIV make me an appointment!!!!!!
Old Jul 18, 2006 | 12:18 AM
truplay8's Avatar
THE BATMOBILE
window motor is dead
Old Jul 18, 2006 | 01:53 PM
candyvp's Avatar
The window motor will need to be replaced at the dealer. My car did the same thing I took it to the dealer and he hit on the door panel above the arm rest and the window went up. They replaced the motor I have not had any new problems it has been about 9 months.
Greg
Old Jul 18, 2006 | 05:50 PM
03G35Black's Avatar
i've had my window motor replaced 3 times already. the first two times replaced by the dealer under warranty, the last time had to pay 450. unfortunately, infiniti doesnt expect the new motor to last more then a year, from my experience.
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
yassy
Aug 3, 2015 12:24 AM
wylin
Lights
Jul 18, 2015 06:12 PM
