Lights - the final answer!
Old Apr 3, 2005 | 02:07 PM
  #151
S-Tuned's Avatar
gtr proto test driver
Originally Posted by drsifu1
Not to burst your bubble, but you coulda saved some money by going to Import Performance Warehouse
I keep on telling people but no one listens.
PIAA 168 Extreme Super Whites for $10.87
Link #1
PIAA H4 Super Extremes for $63.71
Link #2
Didn't do any of the shipping calculations, but you woulda saved money on the bulbs themselves.
I don't work for the above company, I just ordered from them a coupla months back. Shipped item promptly. I ordered a total of 8 sets of wedge bulbs/T-6. No problems whatsoever. You can check out their feedback I gave on them on G35driver "buyer's feedback". I spent a good 2-3 hours trying to find the cheapest place and spread the word, but everyone seems to be going to other places like optauto and now autobarn.
Good luck with your install
6MT Coupe, DG/G, Prem
ok so the lights in that first link are the ones i can use for my corner lights right?
the 168 WEDGE XTREME WHITE 5W or the 168 WEDGE SUPER WHITE-5W
(what looks better and matches better with the rest of the OEM lights)
Old Apr 3, 2005 | 03:21 PM
  #152
escobar929's Avatar
i have the PIAA white/white LED's, IMO they match the HIDs pretty well, they have a slight hint of blue, but i've seen the wedge bulds and they arent bright enough
BTW import performance warehouse is awsome, i've ordered all my bulbs from them, every order has been received w/in 3 days at most
Old Apr 3, 2005 | 04:36 PM
  #153
S-Tuned's Avatar
will the PIAA 168 Extreme Super Whites look good if i still have my stock bulb in the clearance strip?
btw whats up with the leds i know they are better but is it as easy to put in as a bulb?
Old Apr 5, 2005 | 09:44 PM
  #154
imRACERX's Avatar
bulb pic
heres the set-up with 6000K and the blue white super bright LED. the markers actually dont seem to match in the picture but look very close in person. RX
Old Apr 6, 2005 | 07:54 PM
  #156
S-Tuned's Avatar
no remove the wheel liner and hit it from the rear (lol)
Old Apr 6, 2005 | 09:07 PM
  #157
escobar929's Avatar
LED's are just as easy to install, they actually look almost just like the 168's. with out the lights in the clearance they wont match, i suggest you change both to LEDs
Old Apr 8, 2005 | 09:44 AM
  #159
Sickone's Avatar
I did my Clear corners and High beam/fog bulbs last night
I just jacked the car, removed the wheel, popped off the inner front fender well/guard
(which is like 7 or 8 10mm nuts underneath, 7 or 8 of the plastic push rivets, and a 1 philips screw,
I then had access to the entire Headlamp assy, and the clear corners were about 30 seconds each at that point.
I put in the PIAA Super Plasma GT-X - I am fairly pleased.
The factory High beams are just sad, and aweful yellow.
The Fogs are also too yellow.
The new bulbs the brights are a lot better, and both beams are much whiter
Old Apr 8, 2005 | 11:59 AM
  #160
S-Tuned's Avatar
i did it last night too without taking wheel off or jacking car. i removed the 5 clips and one screw then popped it down and got my hand in there.. the clearance light fells like it has a metal rod comming out of it thats how you know your touching it
Old Apr 23, 2005 | 11:21 PM
  #161
crai6m4ck's Avatar
Originally Posted by afr0puff
1. Low Beam: OEM Xenon bulb. No clue about a replacement as most people will leave this one stock.
2. Fog light/High Beam: H4 12v 60/55w
3. Front Turn Signal: I'm 90% sure its a 7440/7443 12v 21w.
4. Side Marker: standard wedge bulb 168 12v 5w for regular bulb. LED replacement does not have a wattage.
5. Clearance Light: standard wedge bulb 168.
http://www.anythingbox.net
So 4 & 5 are both 168? This link is causing me some confusion http://www.sylvania.com/ConsumerProd...RG-Results.htm
It says that
Front sidemarker is 194
Parking light is 168 ?
Then there is this.... http://www.eautoworks.com/html/bulbS...1-INFINITI.htm
Which doesn't list a 168 bulb... maybe 2 vs 4 door?
Old Apr 24, 2005 | 02:36 AM
  #162
Finiti35's Avatar
FGC South Florida BOD
Nah.. 194 = 168 = same thing.. wedge type bulb
Old Apr 24, 2005 | 03:28 AM
  #163
Patentmat's Avatar
I'm new to this thread, and it started out great but got increasingly confusing. Hoping to tame the monster, can we say that the above quote is still correct? Other issues that came up, were (1) that some of these could be replaced with LEDs, and (2) that some of these (i.e. number three) are very difficult to replace
Old Apr 24, 2005 | 03:34 AM
  #164
crai6m4ck's Avatar
How is 168 and 194 the same? There has to be a difference or else it would be the same number. It is confusing and I still need to figure out if I need the 7443 dual or the 7440 single filament. Someone who has changed these please clarify!!!!
Old Apr 24, 2005 | 01:30 PM
  #165
afr0puff's Avatar
Supa Dupa Moderator
168 and 194 are the same. 194 has a slightly thicker base, but it will fit into a 168 just fine.
