Lights - the final answer!
So after reading thisd thread i decided to get PIA #168 extream white for the side markers and clearence.
What do i use to get the same look for the rest of the stock clear bulbs ie plates and what ever else i may be missing.
What PIA bulb #
plates ( rear )
Dome
Sill?
trunk
reverse
Thanks
What PIA bulb #
plates ( rear )
Dome
Sill?
trunk
reverse
Thanks
For the license plate and trunk you can use the same 168 bulb.
Check this site out to find out the replacement bulb numbers
http://www.sylvania.com/ConsumerProd...lacementGuide/
The reverse, dome and sill/step lights you can get from importperformancewarehouse.com once you know the bulb #s. Too lazy to look them up now.
Finiti can we see pics of your new 9 LED setup? Which lights did you choose from superbrightled.com?
For now i ordered 168 PIA extreem White for the Side Markers, Clearence, & Rear Plate. I think that takes care of all the outside "clear" lights except the reverse which i am not that worried about. I may change the Inside lights to White LED In the late future.
Fog Light Help
The Fog light is H4 12V 60/55w ( What is the specific PIA Replacement # for extreem White )
I went to http://www.importperformancewarehouse.com/h4_series?b=1
And still have no idea what to order because nothing matches that Number H4 12v 60/55W?
Thanks for your help
Wayne9011
Jul 27, 2015 11:25 AM
