Why is my G so slow
Old Aug 10, 2006 | 04:11 AM
Cobra-2-G's Avatar
that sucks dude. Next time buy a Cobra to be fast. hehe
Old Aug 10, 2006 | 05:10 AM
Klubbheads's Avatar
Originally Posted by pch2005
i got the car used...it has about 12000 miles. they car has been broken in. I understand a z can be faster but if he is trappping 95mph in the 1/4, auto and the 6mt is suppose to trap 100mph. I mean that is a difference of 5mph which is a lot. Also, i do have premium gas, 91 octane which is the highest that is offered here in AZ. Also, i do have the vdc, but that is only for launches, so i can spin the tires. Doesnt really affect it when you are doing it from a roll. I launch about 4500 rpm, i get a good tire spin but he pulls in 2nd. Car is just slow period and i am bothered by it because it should be faster.
The VDC should be off till atleast 3rd gear redline.
Originally Posted by SeZkI
maybe because 350z is faster then g35? its lighter and quicker but u have Mt so i mean i wouldnt be surprised if he won but spanked is another story that depends on good you are and i hope your racing with vdc off.
6MT G with the right driver should spank(Yes spank 2-3cls till100) auto 350Z
Originally Posted by 99atlantic
because it's not a drag car
if you want a drag car, do like me - build an FFR shelby cobra with a
supercharged 427 in it ^_^
No its not a drag car and no one expects it to be... But racing a auto 350z should be an easy kill with a 6MT.
Old Aug 10, 2006 | 05:47 AM
Tobal's Avatar
It seems like your shift point is too high in rpm causing you lose power and time. You might want to consider shifting at a lower point. like someone else mentioned peak power is reached around 6800 rpm.
Old Aug 10, 2006 | 06:26 AM
kuleto's Avatar
Or maybe you're TOO heavy. J/K!
Old Aug 10, 2006 | 06:47 AM
Klubbheads's Avatar
the tachometer on our cars is off by about 300 rpm, so when u shift from lets say 6800rpm, u actually shift at 6600rpm which is the redline on my car. so if he is shifting at 7100rpm on tachometer then he is shifting at about 6800rpm.
Old Aug 10, 2006 | 08:25 AM
JEVERYDAY's Avatar
Originally Posted by MaDdFLaSheR
meh
LOL
Old Aug 10, 2006 | 08:32 AM
SilverII's Avatar
i think it is the driver...
Old Aug 10, 2006 | 08:56 AM
FAST1's Avatar
I think there is something seriously wrong with me G. I think it is just dirt slow. I raced my brother that has a 2003 350z auto and he spanks me...BAD. He ran a 15.0-15.2 @ 94-95 mph and he is spanking me by atleast two cars.
I have an '05 coupe and I've had it to the drag strip on two occassions. My car is bone stock and my best time in the 1/4 is 14.3 at 101 MPH, and I've never been slower than 14.5 at 100 MPH. It seems from your post that your car is at least a sec slower than mine. If I were you, I'd take my car to the nearest speed shop to have it checked out.
Old Aug 10, 2006 | 09:29 AM
civic4982's Avatar
im nto sure but i think if your going past redline your losing horsepower tell me if im wrong but i think peak is at 6800..or at least thats what im aware of. And you are driving stick so it can be partly on your part too, either way turn vdc off because when your changing gears even off roll you need to chirp (make tires peel a little when changing gears isntead of having traction lock you in) and just keep going i mean your car might have a problem, but i think you should fully see if its on your part or the car? does the Z have anything in its engine?
haha please explain in your own logic why he "need(s) to chirp" ???
I agree with the VDC off but I don't get your logic.
Old Aug 10, 2006 | 09:44 AM
g'dup13's Avatar
i think ur not launching at the right rpms.. i have an 04 and i launch at 2.5krpm or 3krpm.. also if ur going pass the redline as others say ur not doing anything but reving ur engine... try taking ur car to an open area and learn wha rpm its good for u to launch without burning rubber in one spot and wa rpm to shift into 2nd and 3rd... on mine its about 6.2k rpm slap it into 2nd. anything pass that its jus a waste.. thats prob why ur getting spanked.....
Old Aug 10, 2006 | 09:48 AM
tekknikal's Avatar
agreed
Old Aug 10, 2006 | 10:07 AM
rgolden90's Avatar
totally agree
Old Aug 10, 2006 | 10:10 AM
trey.hutcheson's Avatar
First, when you say the z only traps around 95, what are the conditions? Is it high altitude? The assumption that your car will trap 99 to 100 is based on good conditions.
Second, ignore all these people telling you to shift earlier. You've got the revup motor, which holds peak power all the way to redline. There is no reason to shift earlier. And Klubbheads is right about the indicated rpm; the tach on your car reads high. So shifting at an indicated 7200 is closer to 7k, give or take, and depending on gear.
Klubbheads is right again about vdc. Vdc shouldn't be on any time you race. Period. If it's wet outside, you shouldn't be racing anyway.
And you're launching too high. There is no reason to launch at 4500 on street tires. You'll just spin. Not to mention that will kill the clutch. Launch at a more conservative 2500 to 3k.
Lastly, a CAI will do nothing for the revup. The revup hates CAI's. If you're dead set on an intake, go with the JWT.
Old Aug 10, 2006 | 10:11 AM
Originally Posted by rgolden90
totally agree
If you're shifting that early, then you're losing power. Sure, the engine may peak at 6200rpms, but the torque multiplication of 1st gear is great enough that you should shift at redline.
Old Aug 10, 2006 | 10:58 AM
  #30
redred7139's Avatar
I just bought a CAI, nothing too high performance, but will that hurt my revup?
