Can u hear ur valves clicking at idle?
Old Sep 12, 2006 | 02:02 AM
VicThaDish's Avatar
Originally Posted by MrElussive
Might be the clutch plate. Makes a clicking sound that comes from under the car, but sounds like it's coming from the engine when windows and sunroof are closed. It happens when you have the clutch pressed in or fully let out...I'm pretty sure when sitting in Neutral and clutch fully let out.
+1...I thought the same thing the first week I had my 05 Cpe 6mt...I heard it when I got home. Step on the clutch and see if it goes away. Then, release it and see if it comes back. Quick thing to try before taking it to the dealer.
Old Sep 12, 2006 | 08:51 AM
Baluchitherium4's Avatar
I've noticed that almost every other G I've listened to has a noise that I would consider normal valve train/injector cycling noise.
I don't think I've ever owned a car that I couldn't hear a slight bit of noise from the valve train.
If your oil is full and the noise isn't very loud, I would say it's normal.
Old Sep 12, 2006 | 03:14 PM
Msedanman's Avatar
O.F. Administrator
+1 on the injector noise. Sounds like valvetrain, noise but isn't.
C.
Old Sep 12, 2006 | 03:20 PM
Hi-TechG35's Avatar
Yeah the clutch plate is a noisy s.o.b When I got my G I thought I drove it to hard and then the dealer told me that the clutches in those cars are noisy anyways. My friend has a Z with a stage 3 clutch and it sounds like something is going to explode!
Put the car in one spot after it's parked, shut off the radio and A/C, and listen to the noise. Go into 1st gear with the clutch pushed in and see if it's there. Then go into neutral and let the clutch out and see what happens.
I swear man, with my 03 G I thought it was engine knock or something but then I realized it was just the clutch plate....you may very well be hearing the same exact thing.
Old Sep 12, 2006 | 06:21 PM
Jining's Avatar
LOL ok it must be normal then, thanks guys!
Old Sep 12, 2006 | 06:54 PM
fortified's Avatar
Just listened closely to mine today, damn it sounds good! Nothing like 'mechanicals' doiing their job!
Old Sep 12, 2006 | 06:58 PM
Brando's Avatar
Wink
Hummm....All I hear i this weird whistling, turbine sound.......
Old Sep 13, 2006 | 02:22 AM
Jining's Avatar
Hmm i think if you take out ur vortech and then send it to me, the sound should go away
Old Sep 13, 2006 | 09:06 AM
fortified's Avatar
Wait long enough, someone always comes up with a solution!
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
