Best way to hold the trunk down?
Old Sep 15, 2006 | 06:42 AM
Dan_K's Avatar
I am going to be transporting a bumper in my car from SD to LA and it definitely won't fit in my car completely. So I and going to let a little bit of it hang outside and try to hold the trunk down with some rope or something. What's the best way to approach this? My trunk has the older oem spoiler. Thanks guys.
Old Sep 15, 2006 | 07:31 AM
GTT's Avatar
GTT
G35 Twin Turbo
call friend for help or so, but please don't do it like this.
Old Sep 15, 2006 | 09:36 AM
LI-G35Driver's Avatar
It may fit.. I just bought one and took my Altima to get it... it fit fine and I actually think it probably would of fit in the G... try turning it on its side and see... Good luck with it...
Old Sep 15, 2006 | 09:43 AM
TURBOTOM's Avatar
a.k.a kleicoupe
what about folding the rear seat down???
You would be better off goin with a friend who has a larger car....
Old Sep 15, 2006 | 09:52 AM
izmir41500's Avatar
G35driver Addict
+1 for folding the rear seat, better getting a friend with a bigger car.
Old Sep 15, 2006 | 09:59 AM
TheKnite's Avatar
If you absolutly have to then the best way to hold it down would be with the bungee cord with hooks on both sides, they sell those in automotive stores and they come with different sizes and lenghts. But like the guy above said, try to fold the seat down and somehow fit it in. Good luck.
Old Sep 15, 2006 | 10:01 AM
Brando's Avatar
Cool
Ummm....Bungee Cord.
Old Sep 15, 2006 | 10:17 AM
giddyup69's Avatar
i tried tying the trunk down once when my cooler wouldn't fit into our joke of a space trunk. unfortunately, i couldnt' find a secure method for tying it down... so i took our mini cooper instead.
Old Sep 15, 2006 | 10:29 AM
GT-Ron's Avatar
You might find more room within the cabin. Fold down the rear seat and the front passenger seat and do whatever it takes. I've had to get things in through the door that wouldn't make it through the small trunk opening.
And as for the bungee cords, if you have to leave the trunk open, use blankets to cushion the trunk lid and then cinch the rope/bungee tight. You don't want the trunk lid bouncing up and down at all, if you value your paint or the item your moving.
HOWEVER:
My bet is that you'll fit it inside the cabin/trunk with the trunk closed. You don't want to be sucking in exhaust fumes from SD to LA, which is exactly what's going to happen with the trunk open. Ever notice how dirty the rear bumper and rear of the trunk get? You'll suck in a lot with the trunk cracked open 6+ inches.
Old Sep 15, 2006 | 01:26 PM
timbo's Avatar
I fit a rear bumper & 2 side skirts inside my coupe before. You have to knock down the rear seats & recline the passenger seat all the way. Bumper fits from passenger leg room to rear seat on driver's side. Your rear view mirror becomes useless though.
Old Sep 15, 2006 | 01:35 PM
Calvin's Avatar
Overglorified Altima
i fit my nismo front bumper in the g
Old Sep 15, 2006 | 03:04 PM
aK@kminfiniti's Avatar
Just tape it on to your original front bumper
Old Sep 15, 2006 | 03:08 PM
LjN_728's Avatar
+1 It should fit between the driver and passenager console. I wouldn't leave it hanging out because what happens if you go over a hard bump, the trunk lifts and slams down on the bumper? Ouchie!
Old Sep 15, 2006 | 03:13 PM
avs007's Avatar
I don't understand why it's so hard to hold the trunk down.... Use a bungee cord, or a piece of rope.... Then you slide one end into the latch on the deck-lid, until it clicks and latches onto it... Then you hook the other end onto the latch on the bottom. Works really nice if you have adjustable cords, like the ones I use.
To remove, just hit trunk-release, and the latch will let-go of the rope/cord.
Old Sep 15, 2006 | 03:17 PM
avs007's Avatar
This is true if you're not in motion, but if the car is moving, especially on the freeway, you will not suck in any air. Air would flow out, from inside the cabin, not the other way around.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
