question on 04 g35 coupe engine
Old Sep 19, 2006 | 08:39 PM
mephistomyhero's Avatar
I really see where they are coming from by saying to use the search. However, I have to agree with you on this one. The "+1 lol.." gets really anoying, more so then you not using the search button. I think what you should have said was "I used the search but I couldn't find anything updated or useful, so I wanted to ask this question...", even if you didn't . That way, they won't say to use the search I, for one, hate it when people won't post anything useful after the first couple of "use the search" button. From what I found by using the "search button" is to get the 5/16 spacer AND the MREV +. Although, even I can't figure out why/how it was changed from the old MREV. I swear the original MREV didn't need the spacer.
Old Sep 20, 2006 | 11:02 PM
nfo184's Avatar
i heard that one 03-04 they come with the mrev and a spacer and should just be upgraded to mrev2....not both ......or maybe just a spacer and not mrev2 ....is this correct?
Old Sep 21, 2006 | 06:09 PM
nfo184's Avatar
Old Sep 21, 2006 | 06:14 PM
abcquackyxyz's Avatar
spacer should be sufficient for you...
Old Sep 21, 2006 | 10:53 PM
nfo184's Avatar
dont they come with one already? and just need to get mrev? or mrev2?
Old Sep 22, 2006 | 03:14 AM
no the spacer doesnt come stock with your car. you gotta get at motordyne..helps your front half of your engine breathe alot better..
Old Sep 22, 2006 | 07:13 PM
nfo184's Avatar
what about the chome kinetex??? intake manifold that has the upper and lower spacer?
Old Sep 22, 2006 | 07:14 PM
nfo184's Avatar
and whats the difference of mrev
mrev2
and spacers
i've read all over and keep hearing different stories on the forums
Old Sep 23, 2006 | 07:58 PM
nfo184's Avatar
ok i finally read about kinetix is bad w/o FI so what spacers do u recommend for a 04 6spd g35 with stillen intake, z tube, and stillen exhuast.....1/2? 5/8? and should i get a mrev or mrev2 and is that a top plenum replacement and the lower also?
Old Sep 25, 2006 | 08:36 PM
nfo184's Avatar
vmcarbuyer
Oct 12, 2019 12:42 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mushu
Jul 15, 2015 03:55 PM
