Expert advice on this please...
Old Sep 23, 2006 | 10:27 AM
HUMMERH2's Avatar
I have plenum and high flow cats. if i add cat back, will I need ECU reflash or will ECU adjust itself after a few miles? if ECU reset, how do you do this?
Thanks !
Old Sep 23, 2006 | 10:52 AM
logik05se's Avatar
ecu reflash will help you get the most from these mods as possible. Doesnt HAVE to be done but its the RIGHT way to do it.
Old Sep 23, 2006 | 10:57 AM
Diamond G35's Avatar
Call your boyz CRAWFORDZ
LOL. Just messing with ya
Old Sep 23, 2006 | 11:10 AM
cmthresher's Avatar
Thumbs up
I'm guessing that it will not reset itself.. take off your negative battery terminal.. And pump the brakes a few times. wait a few minutes and you are ready to go test it out.. Of course after you put the cable back on.
there are posts on another way but you have to be exactly right on the time.
http://www.motordyneengineering.com/manual.asp
You can go to this websight and at the bottom of the instructions they have all the reset examples that you will need.. Good luck
Old Sep 23, 2006 | 11:32 AM
Calvin's Avatar
Overglorified Altima
if im not mistaken, isnt reseting and reflashing the ecu different? when most people say reflash dont they usually mean taking it to TS..and when they say reset then thats when they mean disconnecting the negative battery terminal/use the pedal method?
correct me if im wrong..but thats just what ive understood from reading the forums
Old Sep 23, 2006 | 11:48 AM
Nismo G's Avatar
This is what i thought as well. The reflash is when they (technosquare) reprogram the ECU to the mods that are on your car. The reset is just simply reseting the ECU un pluggin the battery and doign whatever it is that you do to reset the ECU.
I would also say that you should just leave the ecu alone. My recomendation would be just to floor the car around for a while in different gears. Stretch 1st then stretch 2nd then stretch 3rd, but do it all from a stop and let the ECU learn.
Old Sep 23, 2006 | 12:09 PM
Calvin's Avatar
yeh..well..im assuming he just means an ecu reset. dont know why you would spend so much on an ecu reflash for just an exhaust. i would wait to do an ecu reflash after all the mods are done.
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
