Top Speed 6MT - 5th or 6th?
Old Sep 29, 2006 | 07:16 PM
hickey's Avatar
Is top speed achived in 5th or 6th? What RPM is the non-revup coupe pulling in 5th at 140mph?
It seems 6th has serious overdrive.
Anyone remove the speed limiter for track use? Is this software?
Thanks,
Hickey
04 6MT Sports Coupe
Old Sep 29, 2006 | 08:27 PM
pop099's Avatar
Why in the world would top speed be achieved in a lower gear!?!
Or are you asking if it is possible to get to 155mph in 5th as well as 6th?
Any case, I'm fairly sure you must be in 6th to get going that fast.
Old Sep 29, 2006 | 09:07 PM
Kyosho's Avatar
Yes, at about 155mph you'll be in 6th gear at about 5000-6000 rpms. eric wanna confirm this?
Old Sep 29, 2006 | 09:20 PM
FastDontLie's Avatar
...we dont need roads...
At 145 in 6th I think you'll be around 4500-5000. So I figure youll be aroud 5500 at 155. Not sure its been a while
Old Sep 29, 2006 | 09:26 PM
Klubbheads's Avatar
5th tops out at 130-135 so to get to 155mph you have to put into 6th.
Old Sep 29, 2006 | 11:26 PM
Pwoz's Avatar
Just an FYI, you won't need to remove it for tracking, you're never going to get to that speed without a longass straight. Is it just me that thinks the 6th could be longer for the freeway?
Old Sep 30, 2006 | 11:46 AM
chobble19's Avatar
mine 6MT will NOT go past 146mph! GRRRRR
Old Sep 30, 2006 | 12:15 PM
uberchicken's Avatar
It's actually not uncommon to go faster in the second highest gear. Top gear is often over tall for highway cruising/efficiency and at top speed the gearing is too high and the engine cannot overcome the wind resistance. It wouldn't surprise em at all if 5th was as fast or faster on top in the G.
Old Sep 30, 2006 | 12:22 PM
DaVince's Avatar
you mean on 6mts right?
because if its 5mts the 4th gear tops at around 100 to 120mph
Old Sep 30, 2006 | 12:25 PM
BadBoy06's Avatar
This doesn't apply to the initial question. My rev-up machine got to
146 in 5th and I had to hit 6th to get to 155.
Now I did face some head winds on that run so maybe that was a
factor?
Old Sep 30, 2006 | 03:17 PM
inspector_yoo's Avatar
I'm in the same boat at chobble. But I'm auto, and when I have it in 4th in manumatic it goes to 145. When I put it into 5th, it just stays at 145.
Old Sep 30, 2006 | 03:59 PM
Aman's Avatar
I agree, this engine doesnt have a lot, but it has enough low end torque to be at like 2600 rpm at 80mph instead of 3000 rpm.
But our tranny's are supposed to be close ratio boxes, so the faster in a lower gear thing doesnt really apply to the G's.
Old Sep 30, 2006 | 06:22 PM
partyman66's Avatar
Yeah, I agree. Our engines have enough power to pull lower RPM's on the highway via a taller 6th gear. 3K @around 81 or 82 MPH is a little high for a performance V6 with such a fairly large displacement.
Old Sep 30, 2006 | 07:32 PM
Jtrain's Avatar
weird...
Old Sep 30, 2006 | 08:44 PM
factor?
You are correct, it has nothing to do with the original question. It has to do with the one I quoted.
I never said this was the case with the G, I just said it could be and it IS with some other cars. I've read a few top speed tests on HIGH speed cars, 190mph+ where the testers got a higher speed in 5th than 6th.
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
nervseele
Jul 17, 2015 11:21 PM
