smog test?
Old Oct 5, 2006 | 10:08 PM
xx7sephiroth7xx's Avatar
G
smog test?
So I went to my Infiniti Dealer to check out whether or not a Z-Tube would void the factory warranty. The guy I talked to said that it would not, except every 2 years I'd have to reinstall the stock tube 1 month before the smog test.
Why is this? (I understand installing it 1 month before, so the car can "learn" the new configuration with the stock tube, but why do I have to change it for the smog test at all?)
Old Oct 5, 2006 | 10:33 PM
nm3th's Avatar
Then I guess all the guys with a stock 350z will have a lot of trouble passing smog...
I wonder what they'll change their stock tube to?
Don't worry dude, the guy is just bull****ting you.
Old Oct 5, 2006 | 10:34 PM
G3Fizzive's Avatar
It won't pass the visual inspection. It's gotta look stock (OEM).
Old Oct 5, 2006 | 10:37 PM
nm3th's Avatar
I highly doubt that anybody that doesn't own a z or a g would be able to tell a z tube from a stock tube.
Old Oct 5, 2006 | 10:41 PM
G3Fizzive's Avatar
My bad...I assummed he had JWT in there also.
Old Oct 6, 2006 | 01:00 AM
G
yeah, i plan on using the stock airbox, no other short ram intake (air temp not that different) or cai(hydrolock)
the guy also said that the oil from a drop-in K&N filter screws up the MAF sensor or something like that over time, which he said was $700 to fix. Is this true?
Old Oct 6, 2006 | 03:03 AM
Calvin's Avatar
Overglorified Altima
youll be fine. plenty of people have k&n drop ins. if there was a problem as big as that then no one would use it. youll be fine. anything happens, swap it out and take it back for warranty. but like i said, you should be fine.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
