If i lower my car.....
Old Oct 12, 2006 | 06:29 PM
Klubbheads's Avatar
Originally Posted by Gdup35sedan
There's no way they could legitimately get your car back into factory specs with the S-techs, are you sure you let the springs settle before you got the alignmnet done? I just did an alignment on a coupe the H-techs and could barely get it back into factory specs with the oem adjusters. The front camber is definitely way out because there is no factory camber adjustment.
Keep in mind s-techs for coupe drop the car about 1.2 in the front and 0.7 rear. So there is a possibility that he got the alignement close to factory specs. For sedan it would be a different story.
Old Oct 12, 2006 | 06:58 PM
Calvin's Avatar
Overglorified Altima
g35 s techs are -1.2/-0.9
Old Oct 12, 2006 | 07:04 PM
Klubbheads's Avatar
^didnt feel like looking the exact numbers up, but i was close.
Old Oct 12, 2006 | 07:07 PM
Calvin's Avatar
^^indeed you were
just wanted to make the numbers clear
Old Oct 12, 2006 | 07:22 PM
kennyz424's Avatar
Can you guys post how much dropping our cars will roughly cost...and did it effect the ride for anybody! and last Q... which are the best in the market!
Old Oct 12, 2006 | 07:25 PM
2006_G_coupe's Avatar
+1^
Old Oct 12, 2006 | 07:29 PM
Calvin's Avatar
^^best springs..? dont you guys learn? -___- this is subjective
as for how much it costs? that differs too
if you get h techs then you shouldnt need a camber kit so itll be cheaper
if you drop it more than 1" youll want/need a camber kit which will cost more
springs themselves starts at 140ish and can get up another bill or so
installation ranges from 150-225
each setup is different...
Old Oct 12, 2006 | 07:39 PM
Im a slow learner can you please tell me again.. LOL Thanks cuzz.!!^^
Old Oct 12, 2006 | 11:05 PM
20004DSC's Avatar
To the original poster. If you lower your car more than an inch you'll want to think about getting camber kits, front and rear, if not all then the rear for sure. If you want to be buying tires every 12-15k miles then you can lower the car more than an inch without getting camber kits. The struts will hold up for quite a while if you dont lower it more than an inch. If you totally drop it, they might last up to 20k miles... MIGHT. Look into tokico D-spec shocks if you dont want to get coilovers.
-GP-
I let the springs settle for more than 2000 miles, when I needed new tires I had the car alligned. Before the allignment the camber was -2.4 in the front and -1.3 in the rear. After the allignment the camber was -1.6 in the front (-1.5 is spec) and -1.0 in the rear (right at spec). Before the allignment the car handled great, but had terrible tire wear, afterwards, the car still handles great but not as well. However, the tire wear is much, much better. Trust me, I did my research.
Old Oct 13, 2006 | 12:40 AM
Kyosho's Avatar
please do get a camber kit, or after a couple K your tires will look like this (~2 inch drop).
Old Oct 13, 2006 | 12:47 AM
Klubbheads's Avatar
2 inch drop at the rear is tooo low. And yes you do need a camber for that kind of drop.
Gdup35sedan's Avatar
ENVautoDetailing.com
Then you have cambers kits in the front and rear. There's absolutely no adjustment in the front camber of any g35 without a camber kit. The rear isnt possible to get to -1.0 without a camber kit, unless your toe is completely out of whack. You better hope the shop you took it to isnt fakin the number when they give the car back.
-GP-
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
